xu7 engine
xu7 engine
After some mechanical issues with ford festiva's engine, I decided to test another engine "XU7-jp4 PSA".
The cranking is good and engine is working - not as good as BOSCH MP7.3 - the original ecu -, but its working.
Anything is good till the throttle is closed, else the engine will shut down.
>>The steeped is not installed yet.
Engine specifications :
~ 1.8 lit
110 Hp
reline : 7000 rpm
crank rpm : 1800
working temp : 85-90 c
4 cylinder 4 stroke
TDC - crank sensor 's angle : 114
injector flow 100 cc/m ( this is what i found when it's working good )
Note : the MAP sensor is connected and working, all sensors all connected and working.
I tried to :
Setting up algorithm : MAF - result ==> it's working at idle so nice -
Setting up algorithm : MAP - result ==> it's working at 1800 RPM in idle and i can open throttle without engine die -
running engine with mp7.3 - :
A -) fuel management - cutoff at 3000 RPM, throttle, engine temp,map
B -) ignition management - no cutoff at 3000 RPM, engine works fine, just coil
Something is wrong i don't know
I will make a video as soon as i can.
Thanks
~ 1.8 lit
110 Hp
reline : 7000 rpm
crank rpm : 1800
4 cylinder 4 stroke
I tried to :
Thanks
Re: xu7 engine
Please post your tune file and your log files. Video is always nice to have as well
Re: xu7 engine
log+conf
Re: xu7 engine
Any chance for a video? Without being at your place it's impossible to guess which part goes wrong.
Re: xu7 engine
I'm at work for a long time and i will post a video
, perhaps 3-4 days later
Re: xu7 engine
Nice progress, and I see you've gone green.
Re: xu7 engine
The phone was not mine and has no enough memory, so the owner decided to ... anyway , excuse me and i apologize for this.
And what a bout shutting of the engine, i did not turn the switch off or like that. The problem is ....
Re: xu7 engine
my be soft screen recorder + phone recorde ...
Re: xu7 engine
Do you have a log file for the run? A log file tells us many things. It sounds like it was running perhaps rich, or lean, and eventually stalled. Was the engine warm, or cold-ish? It might need some cold enrichment, etc. Log files and your tune would help people comment about why it went wrong.
Re: xu7 engine
Yes i do
Re: xu7 engine
I see the warning counter went from 77867 to 77878, this could be an issue. Perhaps it's having some trouble with crank decoding. As well "trg err" went from 30 to 38. It seems you errors happened mostly at low RPM, so it's not why your engine stalled, but it could be of concern. This can probably be ignored for now, but keep in mind if it gets worse, it could prevent you from starting.
I do not see idle air control. It is common that at idle you need to vary the air which varies the engines power. Your base injector pulse of 3ms may indicate you need this air control. Your injector are probably barely open, and when this happens the fuel delivered vs the expected fuel delivered has a tendency to vary. I would typically expect this to be a problem closer to 1.5mS, so I doubt that's the issue, but it could be a contributor factor. Can you get it to run with the by using your foot to vary the air?
It appears it expects to deliver the same amount of fuel, yet I see the fuel duty cycle varies quite allot which indicates varying fuel. It is likely that you simply need to adjust the low load and low RPM in your tuning tables adding more fuel. However I tend to think your larger issue is that when RPM drops, it likely needs more air to maintain RPM.
Also your tuning files / tables can be handy, as it allows people to inspect the engine parameters.
Re: xu7 engine
After a couple of months ! I'm trying to rerun my old engine with "frankenso" , I remember that it was a running engine.
last days I was thinking why my engine is working too bad ... I guess map & fuel does not match with my engine.
Here i have my logs.
Unfortunately because of sanctions i'm unable to buy / upgrade TS.
So please somebody can analyze my logs ?
Thanks.
Do not trust to autocomplete
Thanks.
Re: xu7 engine
https://github.com/rusefi/rusefi/wiki/HOWTO-upload-tune
https://github.com/rusefi/rusefi/wiki/HOWTO-upload-log
