Bmw 850 ci M73 supercharged
Hi I have a Bmw 850ci M73 1996 euro specs supercharged but after the supercharger installation it turns on a big nightmare because ,bmy ecus are almost imposible to tune because those are Motronic 5.2 That has OTP EPROMs no reflash eproms so my car has been on different shops the last 5 years because here in the states no body could comunícate with the ecus because does not have a obd2 connector just an round connector on the engine bay so I hope you could help me or find some solution because the oem ecus and eml and tcu are so married with the car, so maybe you could get som e solution with your rusefi protus m73 stand alone
Re: Bmw 850 ci M73 supercharged
Where in the states are you?
We have zero interest to handle weird stepper motors and weird pedal - we prefer simpler modern ETBs and simpler modern pedals see https://github.com/rusefi/rusefi/wiki/HOWTO-M73-v12-on-Proteus
Your 96 harness is probably not using https://www.ebay.com/itm/333779143374 like my 1998 but maybe https://www.ebay.com/itm/333833818007 so someone would have to solder wires to those https://www.ebay.com/itm/333833818007
Biggest unknown is what kind of CAN messages is that gearbox expecting. We can make rusEFI send any CAN message as long as we know which ones are needed, which we currently do not know. Maybe someone on the internet would be available to help, maybe gearbox would be happy without CAN messages.
Also question who exactly would do what work
Would it be @abricos soldering custom harness at $90 an hour? Would it be you?
you can fix the Transmission problem by going with a Manual 6 Speed Getrag 420
That is what i did on my V12
and increase the value of your car by $20,000
you can run the rest of the car / CAN by just Spoofing the engine / ECU CAN outputs...
Then the rest of the chassis can do its operations thinking the ECU is working fine ...
https://rusefi.com/forum/viewtopic.php?f=2&t=1749&sid=f2d185a5932a1e63fd6ea7c37d7771fe&start=120
I am in texa
Yes I thing my ecus has this connector https://www.ebay.com/itm/333833818007
. So do you recommend the Nissan Hitachi SERA576-01 60mm throttle body recommended. instead th oem throttle bodies ? Those
The Nissan throttle bodies have to machined to fit on the m73 intake manifolds ?
Any tutorial or advice how to do this, you can run the rest of the car / CAN by just Spoofing the engine / ECU CAN outputs...
Then the rest of the chassis can do its operations thinking the ECU is working fine ,
You need a professional
the nissan v6 throttle bodies just need to have their mounting holes enlarged... to fit the bmw intake manifold.
takes 10 minutes ...
then you can run a modern ECU
everything else is pretty standard -- the OEM BMW stuff works fine
the crank sensor, the cam sensor, the temp sensor, the fuel injectors , etc all that stuff works fine
i use the GM "yukon" coils, they work fine , so you can ditch the distributors and crap
the OEM Engine has THREE siemens ecu boxes attached to it
not sure what they do, but there are lots of them
you might want to keep the original parts in your garage-- not throw them out, and not hack the loom up too much, since people want "original " when buying cars...
andrey did make a harness for the Proteus ECU, and it plugs into the stock wiring connectors, so you don't have to butcher the wiring loom
I don know if this photo data link can bus could help
mine is M73N but here we have non-N M73
is that everything on your CAN BUS?? just 5 boxes? and 4 of them are crap can be taken off?
so the only thing you want to save is the "slip" box on the CAN bus?
this unit will get you close-- may have to modify some connectors, but you get the idea... It is doable ...
https://www.ebay.com/itm/rusEFI-Proteus-BMW-M73-v12-standalone-ECU-with-PnP-harness/333805057834?hash=item4db854f72a:g:IIYAAOSwE~9f9eSd
do you have pictures of your engine/ supercharger setup?
also, here is a manual tranny for your V12 https://www.copart.com/lot/59305320/salvage-1995-bmw-540-i-nc-raleigh
that is not turn-key - welding modification of the bellhousing requiredbill wrote: ↑Tue Mar 02, 2021 2:19 amalso, here is a manual tranny for your V12 https://www.copart.com/lot/59305320/salvage-1995-bmw-540-i-nc-raleigh
Here are some photos of the supercharger
are you running the supercharger currently? i see there is no belt on it in the photos ...
also, where are the OEM MAF sensors? did you move them to a new spot? there are 2 MAF, correct?
i added a bosch Temp MAP sensor to the intake manifold and got rid of the OEM MAF sensors
Yes has two maf sensors just habe been relocated see photo attached
so the car just ran about 300 miles with the supercharger It took about a month for the ecus to learn the new forced induction and bigger injectors parameters but after a month the car start to run well ,the engine really awake it broke the tires since low rpms, he problem was that the guy that sold me the kit when he came to install it left a supercharger oil cooler hose lose ,so when I picked up the car from the shop on the first drive , when I have arrived to my home I noticed that It had a big oil leakage so I noticed that the oil cooler hose from the supercharge had pop out so ,I call the guy to let him know and I re plug the hose and add supercharger oil but after a month when I was on the freeway at high rpm running with a mustang suddenly I felt that the car lost power so the belt from the supercharge was broken and then started the nightmare because back then in 2013 I did not work on my cars my self like now so 3 shops and thousands of dollars wasted no one could restart the car again once one of them reinstall the S/c belt until the last one took off the engine and noticed that the supercharger was stoked so that was there reason that the car did not start but the guy went to jail so now I an struggling with his wife that now is in charge of the shop so they started to work in my car but they still not be able to get communication with the ecus so that is the reason that I want to see if is there an other ecu options
About map sensor I would like to do that but with the oem ecus that have my car .it is imposible because it is no way to tune them those are M5.2 I,but the 1997 ecus M5.2.1 I know that is possible tu tune it but those are no compatible or nobody knows how to marry with my car
You need someone who would be able to assemble everything and get everything running for you. If you have enough $$$ worst case you would have to ship this car to NJ.
Oops yes I know ,so are you in NJ?
two of the guys is in NJ
everybody else is all over the world
we were all having a chat about your car, and here are some comments ..
just For Your Info
If supercharger lost oil it's 99% Dead supercharger ... If he don't have intercooler ... Impeller and supercharger oil flew inside the engine ..
Minimum it needs the manifolds off, a boroscope to check for FOD damage, the charger checked out and a bloody good clean up
I've seen compressor wheels come apart and end up coming out the tailpipe in a thousand pieces
I've seen compressor wheels stuck in cylinder heads
The whole setup was a ticking bomb. He boosted the engine and relied on the stock ECU long term fuel trim to compensate for the extra needed fuel. I think most ECUs limit the correction to +/- 25 or 30%. Even if that was enough to not have it running lean he was using NA afr and NA ignition timing to run boost on a stock engine with NA CR. I don't think it's just the supercharger that died.
you might want to check out this other stuff, to make sure there is no damage to the V12, before you put a new ECU on the engine...
just For Your Info
Yes the car has an intercooler Ok I bought a new supercharger the car was running after the the belt was broken, once the technician install the belt the car did not start any more i mean he install the belt on the old supercharger they do not know that the supercharger was almost stocked sot two different shops where trying to start the car for a wile several months ,I hope that now with the new supercharger the car start again now I will install two inovate AFR gauges to see how it is the AFR even I had installed a begi 2530 Multi role fuel,pressure regulator to help to increase the fuel , but back then I do not have the AFR gauges yet , I thinking to install a split second and enricher and split second PSC1-013P Programmable Signal Calibrato that it is a dual Chanel even a eflexfuel kit just I am waiting that the technician start the car again so let me know what do you think about that so thanks for the advice I will recommend to the technician to check the intake manifold ,so the technician sent the supercharger to rebuild but he said that does not work well and I bought a new one so the technician gaibe me the old supercharger dissembled and I contact to the rebuilder and he said that I have to resend him the supercharger so I did it , once he have received he said that some thing bad happened with the technician because the supercharger was disassembled and has and used parts so I do not Know waht think it about that so he rebuild again the old supercharger and i teste on my son m3 and is working well now so for that reason I am pretty sure that did not sent any piece I to the engine but who knows I will check it to be surebill wrote: ↑Thu Mar 04, 2021 6:13 pmwe were all having a chat about your car, and here are some comments ..
just For Your Info
what is the geographic location of the car ???
Is it posible to set a proteus on a 88 pin conectors and transfer the oem software from the oem ecus to the proteus?I have read the files from my first oem ecus when some guy in Australia was Imstalled Evc boards with 32 pin eproms but one of the ecus that he modified Did not work, just lost my money, i mean i. That way the proteus could get comunication with the whall car?AndreyB wrote: ↑Mon Mar 01, 2021 7:18 pmWhere in the states are you?
