2006 2.0T VAG engine not sure what is the code.
https://github.com/rusefi/rusefi/wiki/VolkswagenPassatB6
WVWAK73C16P101397
Update: first run Dec 9, 2020! https://rusefi.com/forum/viewtopic.php?p=38819#p38819
I can get you that info if you have more info what car it is
Chief mechanic says he plans to use electric ABS brakes pump.
You don't need the high voltage to open the injector, just to open it quickly. With DI you're in a bit of a rush to get your injection over with, so you can't wait for a 0.5ms+ opening time. Opening time on these injectors is around 100us when using the boost + peak + hold scheme. However, you do need a current limited driver or else you'll burn out the injector. They have a DC resistance of around an ohm, so at 12v they'll be dissipating around 150 watts, which would quickly melt things.
Yes - they will still spray something. I had the high pressure pump on my Focus fail, so it was running exclusively off of the low pressure (~80psi, in fuel tank) electric pump. The car didn't like starting and was stuck in limp mode, but still ran pretty much fine.
I'd recommend trying to start the car first without the high pressure system at all, simply using the in-tank pump. The HP pump has check valves in it such that the low pressure pump will pressurize the rail, which means its function isn't strictly necessary to run the engine. My car will actually let me (albeit with a check engine light) unplug the HP pump while the engine is running without much issue. You won't be able to make more than maybe 100 horsepower, but that's enough to putter around a little bit and convince ourselves that the injector drivers work.
I'll make a separate post about the injector control specifically, but you're pretty close to what those specs mean, but not quite.russian wrote: ↑Sat Dec 28, 2019 5:09 amRandom bosch injector datasheet https://raw.githubusercontent.com/wiki/rusefi/rusefi_documentation/oem_docs/Bosch/Data%20sheet_67828491_HP_Injection_Valve_HDEV_5.2.pdf Maybe we need more or less similar 65-90v @ 13.2A for 500us followed by 12v@~3A for the rest of the pulse? Maybe pin 1 is also positive and pin 2 is also GND for us?
Sunday, 11, October, 2020,21: 10: 48: 10463-VCID:, Software version:, Protocol type: troubleshooting
3C0 907 115 F ,, 2.0l R4 / 4V TFSI 0030,
, Group A:, '101 ,,,, Group B:,' 103 ,,,, Group C:, '106
,, engine speed, engine load, Injection timing, Mass Air Flow, current, fuel pressure, adaptation value, Fuel pump Adapt. ,, Fuel rail, Electric fuel, Electric fuel, Fuel pump
, TIME, (G28) ,,, Sensor (G70), TIME, fuel pressure, regulator, fuel pump, Status, TIME, pressure (actual), Pump 1/2, Pump 3/4, Trip Time
Marker, STAMP, / min,%, ms, g / s, STAMP, mbar ,,,, STAMP, bar,% ,, s
http://www.volkspage.net/technik/ssp/ssp/SSP_334_d1.pdfHow it works
The electric fuel pump always conveys as much fuel as
the engine requires at a particular time.
The momentary fuel pressure is measured by the fuel
pressure sender for lower pressure and sent to the
engine control unit. If this pressure deviates from the
reference pressure, the engine control unit sends an
appropriate PWM signal (frequency 20 Hz) to the
fuel pump control unit. The control unit sends a PWM
control signal (frequency 20 kHz) to the electric fuel
pump until the fuel pressure returns to the map curves.
The J293 controller incorporates a failsafe mode where, should there not be a recognized PWM signal of between 5% and about 95% within 10 seconds after 12V is present on its engine alive KL_15 terminal, it runs the pair of fans at full speed. This is nice to have.
The nominal ranges are expressed as:
~15% ≤ low speed ≤ high speed ≤ ~95%
