some work in progress during the weekend.
Did close the cover, and it was still working
manage to mount to my test bench, there are several things I wan to share with you.
- my crank/cam signal is generated by an Atiny45 and is 36/1 on every 2 revolutions there is one ping from the cam. what I had noticed that if I let "trigger"in tuner studio to be only crank, I have one value for rev/min if I include the signal form cam it almost double the revs. Have to test on real car.
-I manage to attach to my test bench: the MAP, the injector, the idle valve, and one coil with igniter. when rum for the fist time, the ground was so bad that it disconnect the ECU from TS. I change the ground of the spark plug to be the common "chassis" and connection to TS was stable. But it loose sync ever second or two (I have to check if something with my simulator)
