Hello from Guadeloupe (French island in Central America area)
Lyonz
kit assembler
Post by Lyonz »
Hello,
My name is Lyonnel, i'm french ... I live in Guadeloupe, a French island in Central America.
I'm glad to enter the world of rusEfi to work on something other than ms.
I already have 3 cars that I had to install in microsquirt but with what I saw of these projects, I would install rusEfi ;)
Lyonnel
Re: Hello from Guadeloupe (French island in Central America area)
Welcome to rusEfi :)
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Sat Apr 21, 2018 11:22 am
Thanks a lot ;)
Welcome along.
Have you found the wiki? Just in case you have not, here's a link you might find interesting.
https://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board
Lyonz
kit assembler
Post by Lyonz »
kb1gtt wrote:
Sat Apr 21, 2018 12:31 pm
Welcome along.
Yes of course...
I'm going to buy 3 Frankenso (1 for Peugeot 1.6 8s turbo & the others for Peugeot 1.6 16s turbo dragrace) for 2 friends, and a Frankenstein for me.
I already have an ms3x but I want to use some functions that I like (ETB, and other I/O) and the speed of the μP. For my car Audi A4 b5 quattro with engine vw r32 turbo BW s476sx.
If I didn't already have a ms3x I would have made a 100% Frankenso project.
I did not know but I am blue because of its speed against the ms3 μP
Lyonz wrote:
Sat Apr 21, 2018 2:02 pm
But why? :)
Are you looking to get assembled or kits?
Is that a 2.0T with the direct injection an drive by wire?
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Sat Apr 21, 2018 2:38 pm
But why? :)
For drive by wire and more
Kits
Leaving country for 10 days in Monday morning so you want to order now or wait two weeks :)
Why Frankenstein and not Frankenso?
Lyonz
kit assembler
Post by Lyonz »
kb1gtt wrote:
Sat Apr 21, 2018 3:13 pm
It's a vr6 3.2L 24v with BW turbocharger s476sx 76mm ID with drive by wire 90mm from Audi S4 v8 engine
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Sat Apr 21, 2018 4:36 pm
Just for DBW & to try other fonctions, and try the implementation via can bus & ms3x
Lyonz
kit assembler
Post by Lyonz »
For now i'm ready to buy these kits from you
Can't wait 2 weeks. My friend have his dragrace soon
https://www.tindie.com/products/russian/frankenso-diy-kit/
PS: if in doubt of SMD soldering, including fine-pitch SMD soldering, I strongly recommend considering fully assembled boards. Over 75% of kits are never assembled.
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Sat Apr 21, 2018 4:47 pm
I understand.
But when I go soldering it's easier for me to immerse myself in the circuits and the operation. Although I understand that it's more complicated.
I will choose the kit
What is your plan for connecting the board to harness - are you soldering wires to the board or do you have VW ECU side connector? How many pins on the VW connector?
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Sat Apr 21, 2018 5:21 pm
I will use oem ecu box...
No need to buy connectors for the moment
Wire to pin
VW... oem ecu box ... is to small ...
Pic of your ecu ...
There are also connector boards similar to this. Would a ECU harness connector breakout board be of use?
https://rusefi.com/forum/viewtopic.php?f=4&t=1303&p=27823
Lyonz
kit assembler
Post by Lyonz »
kb1gtt wrote:
Sun Apr 22, 2018 10:28 am
Perhaps... let me check.
But really nice looks good.
Thanks
Lyonz
kit assembler
Post by Lyonz »
Who have experience with vw vr6 24v engine with vvt?
what kind of experience are you talking about ???
Lyonz
kit assembler
Post by Lyonz »
Abricos wrote:
Sun Apr 22, 2018 1:38 pm
Exprerience with vvt tuning his settings (solenoid frequency, PID, etc...).
Possible to exchange datas between ms3x & ruefi via canbus (sorry for this question)
Lyonz wrote:
Sun May 06, 2018 5:05 pm
One question, I would like to know if LC & NLS work?
No launch control, not sure what NLS is is. I am a road racer myself so my own focus is on that.
Lyonz
kit assembler
Post by Lyonz »
russian wrote:
Mon May 07, 2018 11:21 am
Hello
It's a shame for me.
On track I can understand that the LC is not so useful.
But the NLS (no lift shift) would be more than useful.
For me and the use dragrace it's complicated
By the way, I received the kit. Thank you everything is nice.
By cons it's difficult to mount and some values of components that are not completely identical to the list on your site. But I will get there.
Lyonz wrote:
Wed May 09, 2018 3:58 am
Can you start a new thread for no lift shift? How would it know that I am shifting on the track? Excuse my lack of knowledge.
russian wrote:
Wed May 09, 2018 12:00 pm
The tl;dr is that when the clutch pedal goes in, the ECU cuts fuel/spark so you don't have to lift off the accelerator. Then, when you're off the clutch again it brings them back after a short delay, and optionally by sweeping in the timing so as to not shock the driveline too hard. The point is that airflow is maintained through the engine during the shift, so that your turbo stays spooled a little better, you don't have to wait on acceleration enrichment, etc.
From my reading, I see it like this. When clutch switch is activated, the soft rev limiter which might normally be something like 7 kRPM get's changed to something like 5.5kRPM. The soft rev limiter typically alters fuel and / or spark to limit HP. If the hard limiter is reached, fuel is turned off completely. By changing the soft rev limiter, you minimize shock, and allow the syncro gears (or what ever gears you have) to do their thing.
Would I be correct is understanding that there is a delay after the clutch is de-activated such that the 5.5 kRPM rev limit is maintained for something like a second or two? I could see how if you miss a gear you do not want to over rev.
We keep discussing in a wrong thread - this information would be impossible to find later.
NLS conversation migrated to here https://rusefi.com/forum/viewtopic.php?f=5&t=1373
Any updates? how many cars run rusEfi with what issues or lack of issues?
