Hi from PR!
Hi from PR!
Sup guys! New to the forum.
Looking forward to learning about RusEFI to be able to contribute!
I'm a recent grad from Electrical Engineering and I'm very interested to see what I can accomplish with RusEFI.
Can someone give me any pointers as to where I should start reading to be able to get started?
I downloaded the bundle zip file to start testing out the firmware before I start investing in the stm32f microcontroller but I'm having trouble connecting it to Tunerstudio. Any help?
Re: Hi from PR!
Hello and welcome!
Out documentation is not best but it starts at https://rusefi.com/wiki/index.php?title=RusEfi:About and https://rusefi.com/wiki/index.php?title=Manual:Software:User/en
What seems to be the exact issue at the moment?
Re: Hi from PR!
Welcome along and good to hear from you.
Electrical you say. Do you happen to have much for software skills? Any interest laying out a PCB adapter board?
We don't have your eyes or ears. We can help, but we need more details about what you are doing and what is going wrong. I think you are trying to do the PC simulation found at this page https://rusefi.com/wiki/index.php?title=Manual:Software:Simulator Is that correct? What is the problem you are having? Do you get error messages, etc.
Re: Hi from PR!
I seem to have the ini file that opens in Tunerstudio and got the console to open with the virtual com software but Tunerstudio isn't responding to the console. Let me check out those links you gave me before I keep asking questions cause I'm just starting out and obviously have much to get started.
Thanks for the quick response!
Re: Hi from PR!
Tunerstudio not responding to rusEfi (?) console? How exactly would you like Tunerstudio to respond to rusEfi (?) console?
Maybe a sheen video? icecream screen recorder is cool.
Re: Hi from PR!
I've worked with Arduino's so definitely feel comfortable coding in C; I have little experience doing PCB layouts but shouldn't be too hard getting started.kb1gtt wrote: ↑Sat Feb 03, 2018 2:06 amWelcome along and good to hear from you.
Re: Hi from PR!
I see gauges in the RusEFI console but the 1200rpm displayed isn't displaying in Tunerstudio.
And I got an error message in Tunerstudio that it attempted to connect to the console unsuccessfully 3 times. It also said something about not having a tune file(msq file). Again, let me read the links you gave me and I'll ask more question when I give this more practice.
Re: Hi from PR!
Usually we do not intend both tools to connect to the firmware/simulator simultaniously. And definitely not connected to the same TCP port simultaniously?
Re: Hi from PR!
wait, I was assuming the rusefi console is to emulate the stm32f4 hardware and that connects to Tunerstudio via the virtual com port or am I way off?
Re: Hi from PR!
You are a bit off.
rusefi-simulator.exe is the thing... simulating the hardware.
rusEfi console is our ecu-specific alternative to tunerstudio.
Re: Hi from PR!
then can I get a little more guidance? right now I don't have the stm32 hardware, just my laptop.
What can I do to get started on learning about this? Do i need the hardware to even begin?
Re: Hi from PR!
Re: Hi from PR!
Ok, so I'm stiiill lost here. I tried figuring it out before I started asking questions but didn't get far.
So I'm following the instructions on the Simulator wiki page and so I open up the rusefi_console.jar file, connect to a serial port COM 3 which I created with HW Virtual Serial Port creator and when i open Tunerstudio I'm not presented with the usb and wireless driver? Why is that?
I don't get this option:
Re: Hi from PR!
These are the only options that come up.
Re: Hi from PR!
Oh wow nevermind. That's part of the paid version of Tunerstudio, no wonder.
Re: Hi from PR!
If you got COM working you are good with Lite edition
Wifi way is easier but requires commercial TS
Re: Hi from PR!
Also I see nothing going on in the console, no RPM, nothing.
Re: Hi from PR!
This is what I see
Re: Hi from PR!
Now I am confused, we have jumped from TunerStudio which is one software into rusEfi console which is another software?
rusEfi console is supposed to be able to connect to simulator via TCP/IP, does not it show 29001 as a connect option? it can also start simulator from that launch dialog.
Re: Hi from PR!
Ok, sorry I keep mixing these things up. So i will only use the console, simulator and the HW Virtual Serial Port.russian wrote: ↑Sat Mar 24, 2018 7:13 pmNow I am confused, we have jumped from TunerStudio which is one software into rusEfi console which is another software?
So these are the steps that i am following:
1. I open up the HW VIrtual Serial Port
2. Create a port with these options: PortName: COM100, IP Address: localhost, Port: 29002. The click Create Port.
3. Now I open up the console.exe (Choose COM 100, 115200) CLick connect.
4. On the Top part of the windows it says (Disconnected Console 20180130; firmware=N/A @COM100
5. I open up the simulator and see this text:
ChibiOS/RT simulator (Win32)
Full Duplex Channel SD1 listening on port 29001
Full Duplex Channel SD2 listening on port 29002
Shell service started on SD1, SD2
- Listening for connections on SD1
- Listening for connections on SD2
Running version:
TODO
commonInitEngineController
initSensorChart
initSettings
I don't know where to go from there or if even doing this right?
Re: Hi from PR!
For console no vom emulator needed. Vondole talks to simulator via localhost tcpip networking
Re: Hi from PR!
I went to record a video and it does not work for me. Let me see if I can figure out out
Re: Hi from PR!
Please download latest bundle again - I believe things are better now. Thank you for your patience reporting the issue, I did not realize this was not covered by automated tests.
