Hi everyone, I just got back from the garage, I need some help with setting up the software bit.
I have started here: https://rusefi.com/forum/viewtopic.php?f=2&t=1275 and now Im at this point where I need some help with setting up the Tuner studio.
Hardware: Frankenso r0.5
Analog Inputs used:
I get readings from these sensors:
- CLT (shows correct temp)
- TPS (seems to work but when I fully press the pedal I got 85.45% reading, is it ok?) - if this happens, you have to calibrate the TPS in Tuner Studio
- IAT (temp looks real)
- MAF (the MAX output voltage is 12V, I think I need to use a voltage divider for now) MAF not used at all
- MAP (will be used instead of the MAF later on)a GM 3 Bar MAP Sensor is used with the Speed Density fuel algorithm.
- AFR/O2 (wired but untested yet) - Finally I got the Innovate wideband controller and a Bosh wideband sensor. All seems to work good with rusEFI!
- CAM (I use the U2003 Op-Amp INP11 to read the signal and it looks like it works. The OUT11(schematic page 3) is physically connected to JP05 which goes to PC6) - must be inverted in TS when using op amps
- CRANK (I use the same Op-Amp INP9 to read the signal but sometimes the signal gets lost, I dont know why...The OUT9 (schematic page 3) is physically connected to JP04 which goes to PA5) - the same here ("invert secondary" feature in Tuner Studio)
Little question for CAM and CRANK signals: these sensors are 12V powered. Therefore the sesors output stays HIGH (12V) and once it is triggered by the wheel it goes down to ground am I right? Should the output signal be lowered to 5V somehow before it gets to the OP-AMP?
Digital Outpus:
- Injectors (all tested and work, I use default see the attached photo for configured pins)
- Spark (works fine, I use U601 for both coil-packs, see photo for configured pins)
- Fuel pump (works)
- Idle Solenoid (I think it works) - now it works, 12V power to the valve was not soldered...
- Tachometer output (I tried to use the Tachometer output and Dizzy out, with U602 High-Low side driver powered form 5V physically connected to pin 2K of the plug but the gauge didn't move when I was cranking
- MIL (not tested yet)
The board gets power when I turn the key, once I start cranking, the discovery board resets itself (is this normal ??), this causes in losing serial communication with PC while cranking. I think its due to a big volt drop when the starter gets power. Will a bigger car battery or a bigger capacitor C1001 help? - This is solved and its more to do with me than the board
It was the PSU circuit, I put the wrong component Q1002 on the board. I was waiting 6 weeks to get the right compoonent and I almost forgot about it
To get the readings from the rusefi_console I had to unplug the board from the PC, start cranking then quickly plug the USB cable to the PC and wait util it connects to the rusefi_console while cranking. I have removed sparkplugs for this test...
When I tried cranking, MAF was disconnected. While cranking I got some big backfires from the exhaust... something is not right...
Please see the attached screenshots from the rusefi_console, Tuner studio, and some other stuff...
P.S The screenshot from Tuner Studio shows Sequential Injection mode, but It was set to simultaneous when I was doing the cranking test. Only the last screenshot from rusefi_console shows a sequential injection mode.
