Hi everyone, I just got back from the garage, I need some help with setting up the software bit.
I have started here: https://rusefi.com/forum/viewtopic.php?f=2&t=1275 and now Im at this point where I need some help with setting up the Tuner studio.
Hardware: Frankenso r0.5
Analog Inputs used:
I get readings from these sensors:
- CLT (shows correct temp)
- TPS (seems to work but when I fully press the pedal I got 85.45% reading, is it ok?) - if this happens, you have to calibrate the TPS in Tuner Studio
- IAT (temp looks real)
- MAF (the MAX output voltage is 12V, I think I need to use a voltage divider for now) MAF not used at all
- MAP (will be used instead of the MAF later on)a GM 3 Bar MAP Sensor is used with the Speed Density fuel algorithm.
- AFR/O2 (wired but untested yet) - Finally I got the Innovate wideband controller and a Bosh wideband sensor. All seems to work good with rusEFI!
- CAM (I use the U2003 Op-Amp INP11 to read the signal and it looks like it works. The OUT11(schematic page 3) is physically connected to JP05 which goes to PC6) - must be inverted in TS when using op amps
- CRANK (I use the same Op-Amp INP9 to read the signal but sometimes the signal gets lost, I dont know why...The OUT9 (schematic page 3) is physically connected to JP04 which goes to PA5) - the same here ("invert secondary" feature in Tuner Studio)
Little question for CAM and CRANK signals: these sensors are 12V powered. Therefore the sesors output stays HIGH (12V) and once it is triggered by the wheel it goes down to ground am I right? Should the output signal be lowered to 5V somehow before it gets to the OP-AMP?
Digital Outpus:
- Injectors (all tested and work, I use default see the attached photo for configured pins)
- Spark (works fine, I use U601 for both coil-packs, see photo for configured pins)
- Fuel pump (works)
- Idle Solenoid (I think it works) - now it works, 12V power to the valve was not soldered...
- Tachometer output (I tried to use the Tachometer output and Dizzy out, with U602 High-Low side driver powered form 5V physically connected to pin 2K of the plug but the gauge didn't move when I was cranking
 ) - Works fine I use one of the 12V high side driver and dizzy out. The tachometer does not really move while cranking anyway
 ) - Works fine I use one of the 12V high side driver and dizzy out. The tachometer does not really move while cranking anyway - MIL (not tested yet)
The board gets power when I turn the key, once I start cranking, the discovery board resets itself (is this normal ??), this causes in losing serial communication with PC while cranking. I think its due to a big volt drop when the starter gets power. Will a bigger car battery or a bigger capacitor C1001 help? - This is solved and its more to do with me than the board
  It was the PSU circuit, I put the wrong component Q1002 on the board. I was waiting 6 weeks to get the right compoonent and I almost forgot about it
 It arrived yesterday and now it is already on the frankenso board. I tested the board at home on the bench and now the board switches off when the supply voltage goes down to around 5.1V which is good as the battery voltdrop will never be that low when cranking. Before with the wrong Q1002 the board was reseting itself at 7.6V - 8V. So the wrong component was: IRFR210PBF and the right one is: DN2625K4-G The difference between them is that the first one it's enhanced mode, while we need a depletion mode in the PSU.
 It arrived yesterday and now it is already on the frankenso board. I tested the board at home on the bench and now the board switches off when the supply voltage goes down to around 5.1V which is good as the battery voltdrop will never be that low when cranking. Before with the wrong Q1002 the board was reseting itself at 7.6V - 8V. So the wrong component was: IRFR210PBF and the right one is: DN2625K4-G The difference between them is that the first one it's enhanced mode, while we need a depletion mode in the PSU. To get the readings from the rusefi_console I had to unplug the board from the PC, start cranking then quickly plug the USB cable to the PC and wait util it connects to the rusefi_console while cranking. I have removed sparkplugs for this test...
When I tried cranking, MAF was disconnected. While cranking I got some big backfires from the exhaust... something is not right...
 Solution: I use the alternative Op-Amp option for Cam and Crank sensors --> Therefore the CAM (primary) and CAM (secondary) must be inverted in TUNER STUDIO, also my trigger offset angle was completely wrong. A timing light gun comes with help here!
 Solution: I use the alternative Op-Amp option for Cam and Crank sensors --> Therefore the CAM (primary) and CAM (secondary) must be inverted in TUNER STUDIO, also my trigger offset angle was completely wrong. A timing light gun comes with help here! Please see the attached screenshots from the rusefi_console, Tuner studio, and some other stuff...
P.S The screenshot from Tuner Studio shows Sequential Injection mode, but It was set to simultaneous when I was doing the cranking test. Only the last screenshot from rusefi_console shows a sequential injection mode.
 and then will do some testing again. The battery must be as old as this car...
  (The cam signal was always good as inverted, just the crank is a mess)
