Ok, so I'm waiting for parts now. Have ordered the r0.5 PCB from eBay, all the components from farnell.com and the
178764-1 64 - Pin Connector from RS.
All the parts should arrive this week.
Have spent all weekend on rusEFI wiki, rusEFI forum, Youtube, Google, Wikipedia
trying to understand what do I need and why...
I have also tried to get the idea
of the 1.8 1999 Miata engine schematic to see what needs to be controlled and what can be skipped. I want to make sure I understand everything before I start messing, so here are my maybe silly questions:
1. For the first run do I care about: EGR boost sensor, EGR solenoid, Purge valve solenoid, CDCV - Carnister Drain Cut Valve, TPCV(no idea what it stands for)?
or can I leave them for now, this also tells how many outputs of the frankenso r0.5 I need to use to begin?
2. To be sure to drive the ignition coils do I use four channels of the 8 channel high/low side driver? Frankenso schematic page 2.
3. This engine uses Hall sensors for camshaft and cranksaft, so can I use the op-amp solution to read these signals? Frankenso schematic page 3.
4. Do I need a wideband O2 sensor or can I use the stock one for now?
Before I start soldering, can I use this topic or should I create a new one once I get all the parts, so all the info and problems won't be in Hello World...
