[rusEfi] frankenstein 0.11 on nissan sr20ve neo vvl #34
matt
donator
donator
Re: frankenstein 0.11 on nissan sr20ve neo vvl #34
Post by matt »
kb1gtt wrote:Do you understand what sequentail is? Please see this wiki page http://rusefi.com/wiki/index.php?title=Engine:acronym-phrases#Sequential
If the ECU does not have knowledge of 360 vs 720 degrees, you can still run the engine. However it will not be sequential, as it would squirt when intake is both open, and closed.
ok, i fully understanding now.
let's say mitsubishi 4/2 tiggers. it is still enough if using only one slot cam signal?
i found 4g92/4g93 cas is 4/1 slot.
which is better? 4/1 or 4/2?
on your 4/1 sensor we are using 4+1=5 marks, not just 1 mark
on 4/2 sensor we would be using 4+2=6 marks, 20% more marks?
but we really need to try the 360 sensor once I have some time to prepare it. My race is in 10 days, I hope to have more time after the race.
matt
donator
donator
Post by matt »
last firmware i use is 28/3/2017 and got update it to 22/6/2017. engine start quite fast and running smoothly.
so, Rusefi will be at my daily drive car.. :D
Hey Matt,
You were asking about when launch control feature would be available - to be honest I have no idea :( For that to happen someone would have to work on that and I doubt that would be me in 2017 :(
matt
donator
donator
Post by matt »
for testing in real world, iam available.
but for writing code, sorry i dont know anything.
matt
donator
donator
Post by matt »
done some testing just now. i use standard nissan ignition coil with distributor. first start couple month ago with individual honda k20 coil. i wonder why trigger offset is 365 (nissan coil) instead of 630(k20 coil)?
tomorrow will do some wideband tuning, hopefully all running good. if all ok, this ecu will be installed at nissan GA16DE by next week.
here is our old rusty race car. :D
Could it be that the signal is inverted and the other coil fires on the opposite signal front?
matt
donator
donator
Post by matt »
here is my cas pinout.
pin 1: gnd
pin 2: 12v
pin 3: 360 slot
pin 4: 4 slot
pin 5: 1st switch on signal ( i dont know what it is)
pin 6: 12v (ignition coil)
pin 7: gnd
pin 8: ignition signal
i start my engine today, it runs few minutes and suddenly stop. key of and on again no rpm sync at all. only pin 3 and pin 5 not connected to rusefi. any suggestion?
matt
donator
donator
Post by matt »
http://rusefi.com/wiki/index.php?title=Manual:Flexible_Logic
I read throughout and not 100% understand. Let says If I would like to control my neo vvl, intake is open at 5500rpm and exhaust is at 6000rpm. Got two solenoids that I believe same as Honda VTEC, on/off type. What should I figure in tuner studio?
Until before recently you could only console, not TS for FSIO. Pretty recently text fields have appeared in rusEfi TS project so see http://rusefi.com/wiki/index.php?title=Manual:Flexible_Logic#Case_study_.235:_solenoid_exhaust_cam_actuator
I've aslo added this example into https://github.com/rusefi/rusefi/blob/master/firmware/config/engines/mitsubishi.cpp so you can invoke set engine_type 16 in order to try it.
matt
donator
donator
Post by matt »
from my understanding, i just figure it out at console and nothing todo with TS?
i trying to figure it with shift light function, looks like it suitable with my neo vvl solenoid.
Are you on recent version of firmware/TS/console?
Please post your currenttune.msq once you make progress or if you have questions.
matt
donator
donator
Post by matt »
yes, i use new firmware. now my engine running nissan primera trigger with standart coil with distributer. before this it running ms2 with 4g63 trigger, 2 of my k20 cop got burn.
got test drive this car for 2-3 days, and like i said before.. next week will race with that rusty nissan march :D
matt
donator
donator
Post by matt »
trying to set up my shift light, and got some fatal error. i can't attach log file, board attachment quota has been reached.
matt wrote:trying to set up my shift light, and got some fatal error. i can't attach log file, board attachment quota has been reached.
Please try 7zip or WinZip to compress your log?
matt
donator
donator
Post by matt »
MAIN_rfi_report_2017-07-28_22_54_42.zip
matt
donator
donator
Post by matt »
CurrentTune.zip
FATAL error: Invalid brain_pin_e: 311223392
Please post a screenshot of your "all pins" TunerStudio dialog.
Also just made changed to the software to make the error message a wee bit more helpful. Can you try latest firmware & post fresh log please?
matt
donator
donator
Post by matt »
what is this mean?
That means it has failed to update firmware :( Why it has failed I do not know. Try rebooting PC and replugging USB cables?
Random guess, have you tried STLink --> update firmware as shown on this wiki page?
http://rusefi.com/wiki/index.php?title=Manual:Software:User/en#While_you_wait_for_the_box
matt
donator
donator
Post by matt »
Yes. I update stm32 firmware. I try program it 2-3 times but fail. My others stm32 disco work fine.
It appears it failed on the first byte it attempted to write. I see it notes " is not erased, verify the memory protection"
Is it possible that you have selected a memory protection feature and have locked up the memory on that board. I have not looked into memory protection, so I do not know for sure, but you message does seem to indicate that is what you have done.
matt
donator
donator
Post by matt »
so, how do i set it back to normal? or in case maybe my stm32disco got fault/broken?
last time when it connect to tunerstudio, i can't burn data.
I'm ignorant about how to correct it if you activated the security features. It's even harder for me as I did not preform the sequence which got it like this. It's probably a $12 mistake.
matt
donator
donator
Post by matt »
i search through all stm32 utility, not seen any of security setup. any chance to fix it?
I do not know how.
matt
donator
donator
Post by matt »
i see my friend selling off 24/1 trigger wheel for nissan/vr4 4g63 6 bolt. my plan is to grab one if it is supported with rusefi.
matt
donator
donator
Post by matt »
trying to figure shit light just now and seen not working. planning to use this to on/off my neo vvl selonoid. i write this message at console:
set_fsio_output_frequency 3 0---> ok
set_fsio_output_pin 3 PC14---> ok
and at this ---->set_fsio_expression 3 "rpm > 4500"-----> console is disconnect
what i doing wrong??
