[rusEfi] frankenstein 0.11 on nissan sr20ve neo vvl #34
- donator
at first it was with cvt transmission, but it cause many problem with standart ecu.
neo vvl not working if not install with full engine and dashboard wiring harness.
i change to manual transmission and ecu was swap with ms2 with 4g63 cam angle sensor.
for now i prefer it running with standard 360 slot cam angle sensor.
i can provide trigger pattern in this weekend.
Re: frankenstein 0.11 on nissan sr20ve neo vvl
Do you have pictures of both sensors, complete units? If these are interchangeable I wonder if one can use Nissan sensor on a Miata?matt wrote:with 4g63 cam angle sensor.
- donator
Left is 4g63 (vr4), right is nissan 360 slot. Still need to modified the plate, if not it not touch the camshaft.
- donator
here is 360 slot look like.
I guess let's begin without the 360 channel, I believe sync works based of the 4 slot?
- donator
sorry, i don't know any about trigger calculation.
so i need to log with only 4 slot?
i can provide this 4 slot in evening or tomorrow.
Yes, please log only 4 slots as first step. Please select 'custom skipped wheel" total=4 skipped=0 while doing that.matt wrote: so i need to log with only 4 slot?
What year/donor is your sr20ve? Want to name this trigger properly.
- donator
4 slot
- donator
i'am also logging for a 360 slot. in case if you need that.
custom tooth wheel is set to 36.
- donator
not sure, but i believe it come from primera p11 year 1995-2002.russian wrote:
20170318 should now sync on Nissan Primara trigger.matt wrote:4 slot
We will deal with the 360 slot 2nd channel a bit later, you can start your car with 4 slots.
will this 360-slot thing allow to track efficiency of each cylinder and measure instantaneous acceleration? just wondering how the whole thing looks like - the trigger and the sensor... at 6000 rpm it means a pulse each 2.7~µs - probably, not an easy task for a microcontroller?
360 on cam is only 3 times more work compared with a 60/2 on crank. We will seepuff wrote:at 6000 rpm it means a pulse each 2.7~µs - probably, not an easy task for a microcontroller?
- donator
in TS it should be nissan trigger or custom tooth wheel? i test both is sync. i'am gonna to re-wired my cas now. hopefully it will start tonight.
Nissan trigger, make sure you are using latest firmware.
- donator
yes. iam using snapshot_20170318_2151_rusefi
- donator
and YESSS!! its start..
- donator
and it start only once, not for 2nd time.. i try with custom tooth wheel rpm show correct, but with nissan looks like not stable and sometime remain 0 rpm. gonna work on it tomorrow.
Do not even try 4/0 custom wheel - it would not work right for sure.
Do you have any console log files? There could be useful info there.
Next time try enable trigger_details & writeconfig commands in console or "print sync details to console" option in TS. This would produce some helpful messages with synchronization progress details.
- donator
just curious, is this trigger event?
this whole line is what you see in engine sniffer in console, raw data for it.matt wrote:out of curiosity, is this trigger event?
- donator
i'am not so understand on issue #314 'faster cranking with battery-backed RAM'.
meaning on my stm32 disc got battery or i must put a battery at the back of my frankenso rev0.2?
https://github.com/rusefi/rusefi/issues/314 is an improvement idea which was not implemented yet. some battery for stm32 does not matter where it would be - but that's just an idea at this point.matt wrote:i'am not so understand on issue #314 'faster cranking with battery-backed RAM'.
- donator
today progress.
with nissan trigger setup in TS, no rpm sync.
with custom tooth setup it start for a 5 second, and engine stop if throtle if press.
i can start engine with standard ecu and log a trigger in console if its needed.
- donator
russian wrote:Next time try enable trigger_details & writeconfig commands in console or "print sync details to console" option in TS. This would produce some helpful messages with synchronization progress details.
can i do this while cranking?
- donator
4 slot with enable trigger_details & writeconfig commands.
- donator
i'am also logging for 360 slot if this is needed.
I've widened the expected cap a little bit. It was from 8.70 to 14.50 and it is supposed to sync on 9.69, 9.62 etc.
We do not need 360 slot data so far. I wonder if it starts on 4/0 because your trigger offset is 180, 360 or 540 off? Did you get a timing gun?
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=38.76/0.02/9.61 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=1
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=0.02/38.76/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=1
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=38.74/0.02/38.76 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=1
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=0.02/38.74/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=37.72/0.02/38.74 @ 5 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=0.09/37.72/0.02 @ 6 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=9.69/0.09/37.72 @ 7 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/9.69/0.09 @ 0 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=38.73/0.02/9.69 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/38.73/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=38.60/0.02/38.73 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/38.60/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=37.89/0.02/38.60 @ 5 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.09/37.89/0.02 @ 6 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=9.62/0.09/37.89 @ 7 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/9.62/0.09 @ 0 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=38.86/0.02/9.62 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/38.86/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=38.84/0.02/38.86 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/38.84/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=37.81/0.02/38.84 @ 5 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.09/37.81/0.02 @ 6 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=9.60/0.09/37.81 @ 7 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/9.60/0.09 @ 0 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=38.75/0.02/9.60 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/38.75/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=38.88/0.02/38.75 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/38.88/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
- donator
it start with 4/0 at 0 degree offset, but just a few second and engine not stable.
with nissan trigger no rpm sync at all.
p/s: no timing gun yet
