my engine start and running with Rusefi!!
big thanks to russian and kb1gtt.
Starting to document these at http://rusefi.com/wiki/index.php?title=Manual:Debug_fieldsrussian wrote:undocumented advanced diagnostics, only documentation is the source code
IAT- i not wired it yet.stefanst wrote:I just took a quick look at your tune. Looks like a good start. I see a few things that could be looked at again:
Topic Engine:
- Ignition Settings: Dwell table is 2.01ms across the board. This really depends on your coils, but 2ms seems really short. More common would be 4ms to 6ms or so. If you have missfires, you may want to try increasing the dwell in that range
- IAT sensor: Looks like you're not using one yet. In order to properly tune a Speed-Density (MAP-based) controller you will need IAT to correct for air-density changes
- Tuning fuel without a Wideband O2 sensor is going to be nearly impossible
Topic Tuning:
- Cranking: Set "Enable Cyl. Cleanup" to "true". Helps you to clear a flooded engine by going full-throttle during cranking
- Cranking: I like batch fire for cranking the engine. Seems a little less susceptible to doing stupid stuff
- Cranking dwell also seems short at 3ms. On my 99 Miata I'm using 8ms
- Baro Correction: Hole table should be set to "1" across the board to start with
Looks like you're making good progress. Don't even bother trying tuning fuel without a means of determining your AFR. It's not worth it....
Good luck!
i am 100% sure my oem harness is like this. ig switch supply 12v to main relay. once main relay activate, it feed 12v to pin85 at fuel pump relay. so we need a ground signal at pin36 to activate fuel pump relay. my issue is fuel pump is no switching. or do i need to add some resistor at green wire to lower the current?kb1gtt wrote:I believe your OEM harness uses a fuel pump relay. If you provide 12V to the fuel pump relay pin in the harness connector, you can have the ECU control the fuel pump. Frankenso has the hi/low drivers which can source current. It appears your relay needs an ECU which can source current, and as luck has it, Frankenso can do that.
You will need to double check the current consumed by the relay. The hi/lo drivers can only handle about 0.125A before we expect thermal concerns start to limit the current draw. So I would say find the pin for your fuel pump in the harness, then with a multi meter in 200mA or 400mA current mode (or what ever your meter has for the lowest current), then connect one side of the meter to +12V, and the other end to the harness pin in the ECU. This should cause the fuel pump relay to click, and you should be able to measure a current. If that current is at or below 0.125A, then you can configure a hi/lo driver chip to activate this relay. If it is more than 0.125A, then you will probably need to add a heat sink to that coil driver, or you'll need to limit the max ambient temperature of the ECU. For now measure the relay current and let us know what you find.
what do you mean launch control input? clutch pedal? some button?mattsabun wrote:where should i wired for launch control input? it is via op-amp channel?
Not much logic in the firmware to use clutch pedal signal but yes, at the moment clutch input is implemented via ADC inputs I believe.mattsabun wrote:yes. clutch pedal type.
looking forward a video!mattsabun wrote:hopefully this weekend i can dyno my car.
It was supposed to be that one but the guy with that Nissan is not very active so it was never finished. http://rusefi.com/wiki/index.php?title=Manual:Software:Trigger#Nissanmattsabun wrote:i saw in tunerstudio, trigger type nissan. it this trigger for 360 slot nissan cam angle sensor?
