http://www.feoa.net/threads/the-escort-gear-ratios-thread.66007/ says 1st 2nd 3rd 4th 5th Rev ratios are 3.307 1.833 1.310 1.030 0.795 3.166
205/50R15 tires.
kb1gtt wrote:I potentially see a couple options. The coil is connected to GND on one side, and signal wire on the other. If you remove the coil, there is nothing pulling that signal low. So you could potentially replace the coil with a resistor. I would say you can start by trying a 1k ohm, and work your way down to 100 ohms if you need to. Keep in mind that 1k ohms will dissipate up to 0.144W while a 100ohm will dissipate up to 1.44W. It it doesn't work with a 100ohm, then you could measure the resistance of the coil and insert a resistance that's closer to that.
Alternatively you could wire a small pull up onto the rusEFI board, then connect that directly to the tach wire, eliminating that igniter as well as the coil.
The resistor came last night. Hopefully tonight I can try it. hopefully it works. If so I'll setup a micro computer fan or something to keep the resistor cool.kb1gtt wrote:That one could work, same as the below. Keep in mind it will make some heat, so you'll want to connect it to some kind of metal to sink the heat and keep it cool.
http://www.ebay.com/itm/1PC-DALE-100-OHM-25WATT-3-PH25A-18-THRU-HOLE-MOUNT-RESISTOR-/262469159704?hash=item3d1c618b18:g:lCQAAOSwFnFWED2G
I'm not sure what your tach is going to be, I would need to see a schematic for the dash to know what's on the other end of those wires. It might look for a higher voltage spike, but I'm not sure.
I believe your theory is wrong. By the way we have the schematics @ http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Protege_1993 - the tachometer is on that schematics, right side in the middle, couple of inches above distributor. Tachometer runs on the igniter wire, not CAS wires - it's just that without the spark the magic is not happening and we still have not replaced the spark with a resistor the right way.Kyocmondeo wrote:But I really want to make the factory tach work. I believe my issues lies in the Cam Angle Sensor. I believe the distributor is sending a extra signal out on one of the wires the angle sensor is not doing any longer. Does anyone have the wiring information for this sensor. I'm thinking maybe I can jumper 2 of the wires to make the signal echo on the right wire. I could also be completely lost here. But that's my thinking simply put the cam sensor is not sending the signal for the tach to read.
My first question becomes how come the tach worked with no load on the coil before. So putting a spark plug on the coil makes no sense to me. We didn't need it before why would I need it now? I can try it but logically makes no sense if it worked before without it.russian wrote:I believe your theory is wrong. By the way we have the schematics @ http://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Protege_1993 - the tachometer is on that schematics, right side in the middle, couple of inches above distributor. Tachometer runs on the igniter wire, not CAS wires - it's just that without the spark the magic is not happening and we still have not replaced the spark with a resistor the right way.
As the most ridiculous test (I hope it's safe) can you put the whole red coil and igniter back together and just put a spark plug into the red coil wire and see if that would help the tach?
But anyway - the "distributor output" wire which makes the aftermarket tach working should be the one to feed the tach, it's just the question of proper voltage and pull-down or pull-up.
Was not the high voltage wire between coil and distributor a requirement to have working tach?Kyocmondeo wrote:We didn't need it before why would I need it now? I can try it but logically makes no sense if it worked before without it.
No after we melted down the cap on the distributor we taped up the end of the wire that was going to the distributor and tucked it away so it wouldn't arc to anything and the tach worked fine. it just needs the coil to be plugged in.russian wrote:Was not the high voltage wire between coil and distributor a requirement to have working tach?Kyocmondeo wrote:We didn't need it before why would I need it now? I can try it but logically makes no sense if it worked before without it.
