The situation so far...
As reported the only difference since the last time it was connected are the firmware updates. I can't imagine this being the issue. I've followed Audrey's instructions and metered out the board. I'm finding 5v and VDD on both boards are near enough a dead short. This is both boards independent of each other.
The Franko board was tested on it's on with the car and 5v was where it should be.
Time to order a new board! Arwell, I fully understand this is an experimental solution and there are risks, if I wanted an off the shelf solution, I would paid $400-1000 for one.
On this occasion, I've been lucky - although it took my laptop down, it doesn't appear to have caused any damage, I hope so as the laptop was more expensive than the car! The car appears fine back on the standard ECU. I think in the future I'll use an older laptop - just in case
