[rusEfi] Two stroke Efi (#14)
Number-One
Re: Two stroke Efi
Post by Number-One »
I´m waiting for parts, maybe +15 days.
Number-One
Re: Two stroke Efi
Arrived
rus084
Re: Two stroke Efi
Post by rus084 »
Number-One wrote:Arrived
what it is?
Number-One
Re: Two stroke Efi
Smd resistores and capacitores.
rus084
Re: Two stroke Efi
Post by rus084 »
oh , right . just never saw packing for SMD.
Re: Two stroke Efi
Jared, do we have the q401 resistor channel side flip documented somewhere? In case Filipe would be using q401 for ignition control?
Re: Two stroke Efi
I don't' think I fully understand the question, perhaps that's because I'm assuming my cryptic schematic is clear :) What I was trying to indicate, is that normally R402 is 0 ohms, and R401 is not populated. Then if you need that funky ignition circuit which was found on at least one engine setup, you would populate R402 with a 100 ohm 1 watt thru hole resistor, and R401 with a 75 ohm 1/2 watt thru hole resistor. If you have any more questions feel free to ask.
Re: Two stroke Efi
The reason to consider this trick here is that it's easier to buy fewer kinds of different parts - since only one coil is needed this would eliminate the need in TC4427
Number-One
Re: Two stroke Efi
One more step, still waiting for parts.
one week more to be finished :D
Number-One
Re: Two stroke Efi
First video
[video][/video]
Re: Two stroke Efi
You could probably engage the starter under normal use, and call that a hybrid :) It's cranking right along in that video. I'd bet it slows down once you have compression.
Does this mean you can attempt a capture of the crank signal pattern? I'm not sure how far along you have gotten the soldering.
Number-One
Re: Two stroke Efi
This's to check the starter motor only. The engine it's without cilinder head, need adjust head compression to this piston.
Re: Two stroke Efi
Number-One
Re: Two stroke Efi
Vr sensor
Number-One
Re: Two stroke Efi
Engine closed and working with carburator. Next step, fit itb.
[video][/video]
rus084
Re: Two stroke Efi
Post by rus084 »
it's great sounds .
Re: Two stroke Efi
I've added some info regarding triggerinfo command on the wiki: http://rusefi.com/wiki/index.php?title=Manual:Software:Trigger#Troubleshooting_trigger_input
Re: Two stroke Efi
Re: Two stroke Efi
I've changed the input pin for you so that you do not need to re-solder anything. Please update to latest version of the firmware and execute 'set_engine_type 29' to re-apply your configuration.
Once you do that, your triggerinfo command would start showing PA5 as your input pin:
I believe you should be able to change the input pin via TunerStudio also.
Number-One
Re: Two stroke Efi
Thanks, tomorow morning i will test it. :D
Number-One
Re: Two stroke Efi
VR input works!
Now I need to count how many small teeth I have after the wide tooth.
Re: Two stroke Efi
Looks like we are getting closer :)
What is your plan for sensors? What are all sensors you have and what are you going to use for engine load - TPS/MAF/MAP?
Number-One
Re: Two stroke Efi
Injector is pulsing :D
Number-One
Re: Two stroke Efi
russian wrote:Looks like we are getting closer :)
We can trie map or tps.
Re: Two stroke Efi
Post by puff »
if you do a tps setup, could you please record a screencast? or just a brief tutorial?
Number-One
Re: Two stroke Efi
puff wrote:if you do a tps setup, could you please record a screencast? or just a brief tutorial?
Maybe i will do it by tps, because my engine only have one cylinder and the map signal isn't constante, it´s like a wave. I think will be hard tune it with map sensor.
Re: Two stroke Efi
Number-One wrote:because my engine only have one cylinder and the map signal isn't constante, it´s like a wave.
Wait a second, this is taken care of! You do not need to worry about the wave.
It is also a wave for a 4 cylinder, that's why we have MAP sampling start angle and MAP sampling window angle, and then we average the values within that window. I guess the same would apply to your one-cylinder same exact way as we average a piece of 1st cylinder wave.
Number-One
Re: Two stroke Efi
:D
Number-One
Re: Two stroke Efi
[video][/video]
Working.
Re: Two stroke Efi (#14)
Hooray, first rusEfi two-stroke :)
Congratulations and welcome to the club!!!
