Hellen88 ETB support
- Creesic
- Contact:
Running it by Andrey, seems as though the BMW Hellen 88 board will support an ETB. I'm doing this to delete the clunky factory IAC to make some room, and I could maybe use a few more features with an ETB anyway.
Would anyone happen to know how I can wire it in? And would anyone have any recommendations of one? Maybe 3" inlet?
Re: Hellen88 ETB support
Once we figure that out I will add some info to https://github.com/rusefi/rusefi/wiki/Hellen-88-BMW
- Creesic
- Contact:
Just wondering if I can assign the pins myself in tunerstudio or something. Need to do a little more research on what wires are necessary on those in order for them to function.
e36? I had done the same thing with removing the IAC and PCV, and plasma cut myself an ETB adapter to fit a vw rabbit ETB on an M50 intake. I can get you a parts list of it, but mines a big ridiculous since im turbo charging it.
"Dave B. 5:03 PM
- Creesic
- Contact:
E34 TU with an NV in it. Used the TU harness. What engine was it from? Might be a simple solution, or I could just run a generic GM part.
Would an M54 intake manifold with ETB fit?
- Creesic
- Contact:
Thanks for this, but no, because I'm using https://www.ebay.com/itm/401736590801 as a manifold. Have to adapt something up to that. Might as well go larger.
That's an interesting looking manifold. Do you by any chance have a dyno comparison to the stock OBD1 intake?Creesic wrote: ↑Sat Jan 01, 2022 7:39 pmThanks for this, but no, because I'm using https://www.ebay.com/itm/401736590801 as a manifold. Have to adapt something up to that. Might as well go larger.
Molex 0039301020 would be the part to solder to PCB. Open question what would you need to make the harness side - that's for DC motor on the ETB. Somewhere there must be pins for pedal and TPS many answers would be in PCB schematics I assume
- Creesic
- Contact:
The more I look at the pinout, the more it looks like I'm just going to have to go Proteus. It doesn't look like this will just accept an electric pedal and ETB without a completely new PCB.
- Creesic
- Contact:
Doesn't look like there's a Proteus in stock, so I guess we're back to modifying the Hellen. I do have that connector, though it's not labled at all for an ETB or PPS.
Would modification to the board to accept those things be simple enough to do?
I am looking at a stack of Proteus ECUs in stock. It looks like you've made some assumption based on something?
I would love to help but I've lost the contest.
Let's begin from the beginning. Let's pick a simple and specific project and approach this one project at a time.
Do you have electronic pedal in your possession? Do you have all information you need to wire in two channels of throttle pedal?
- Creesic
- Contact:
There just went any for sale on eBay. Assumed you were waiting on more to come in.
Context is I'm trying to make an ETB work on my Hellen 88 for my E34.
I do have a PPS I can use and an ETB. I have no clue how to wire it into the Hellen 88 and that's what this post is about. It's not labled anywhere to be used that way.
I need your help in pin pointing where does your understanding of this board end at the moment
Q1: are you aware of https://github.com/rusefi/rusefi/wiki/Hellen-88-BMW
Q2: does above link to https://github.com/rusefi/rusefi/wiki/Hardware/Hellen/hellen88bmw-a-schematic.pdf
Q3: did you have a chance to find J20 and J21 on the schematics
Q4: did you have a chance to locate J20 and J21 on the actual PCB.
Q5: did you have a chance to locate silkscreen of J20 and J21 on the back side of the PCB
Q6: are you currently blocked in terms of deciding how to physically connect to J20 and J21
Please give me a one-five word response for each of these six questions just for me to better understand where are you blocked on the overall journey exactly.
Gotcha. Just clarified that on https://rusefi.com/forum/viewtopic.php?p=44274#p44274
- Creesic
- Contact:
Yes, and no to the rest. Now that I'm going ahead with it, I'll try to learn how to use the schematics. I'll report back here if I come across another issue. Thank you.AndreyB wrote: ↑Fri Feb 04, 2022 3:44 pmI need your help in pin pointing where does your understanding of this board end at the moment
- Creesic
- Contact:
Actually, now that I'm looking at it, where are the + and - connections for the ETB motor?
Still learning to navigate this stuff.
I'm gonna try to cross reference labels from the MRE, maybe I can find it that way.
-Edit: "E-THROTTLE+" or "E-THROTTLE-" do not appear in the Hellen88 schematic like they do in the MRE schematic.
Gonna try to find another solution.
I've located J20 and J21 physically. I understand what goes where here, however I'm still lost on where the E-THROTTLE+ and - are supposed to connect.
Found it? E14 and E15? +ETB and -ETB?
See https://github.com/rusefi/hellen88bmw-issues/issues/47 it would probably clarify
I've also improved https://github.com/rusefi/rusefi/wiki/Hellen-88-BMW#auxiliary-pins section of the documentation just a bit
- Creesic
- Contact:
Gotcha. J19 is the DC motor + and -AndreyB wrote: ↑Thu Feb 17, 2022 7:28 pmSee https://github.com/rusefi/hellen88bmw-issues/issues/47 it would probably clarify
J20 and J21 are for the TPS and PPS. Thanks Andrey!
- Creesic
- Contact:
Proposed this addition to
https://github.com/rusefi/rusefi/blob/master/firmware/config/boards/hellen/hellen88bmw/connectors/main.yaml
so that I can actually assign the inputs I need for the external TPS and PPS.
- pin: Aux PPS2
# H144_IN_AUX2
class: analog_inputs
ts_name: Aux PPS2
- pin: Aux TPS2
# H144_IN_AUX1
ts_name: Aux TPS2
- pin: Aux TPS3
# H144_IN_AUX3
ts_name: Aux TPS3
Now what I need to figure out is how to add PWM2 and PWM3 (ETB + and ETB - respectively (C6,C7)) unless that's already just gonna be set?
- pin: Aux PPS2
# H144_IN_AUX2
ts_name: Aux PPS2
- pin: Aux TPS2
# H144_IN_AUX1
ts_name: Aux TPS2
- pin: Aux TPS3
# H144_IN_AUX3
ts_name: Aux TPS3
thank you https://github.com/rusefi/rusefi/commit/6f5af0b0e1d97ac896cb84685221b7e348b3cdb2
for ETB drive I've changed https://github.com/rusefi/rusefi/commit/78517df59816b44a2c2cd286a900a6d02d11bf53
please try again once both build in a about an hour
- Creesic
- Contact:
Need one more because PPS1 isn't selectable.
I think it's pin 37 on the STM32, so...
- pin: PPS1
# H144_IN_PPS
ts_name: PPS1
But I'm unsure if "EFI_ADC123_IN3" is correct.
- pin: PPS1
# H144_IN_PPS
ts_name: PPS1
Any luck with all the updates?
Any pics of your overall setup - is it still on the bench or already on the vehicle?
- Creesic
- Contact:
I'm still figuring everything out, and just got it to fire on all 6 cylinders. I'll document everything after it's all worked out.
Apparently you have to set ignition settings to wasted spark with "Individually wired wasted spark" set to true. I had it set to individual coils, and it only fired on cylinders 1,3, and 5.
