Hellen 128 question m113 5.0
Hello, I have m113 5.0 306hp and want to make it run with manual trans... So my question is can the hellen128 become with software or I need to make it myself via TunerStudio. Does the ecu become assembled or I have to solder all components myself? Best Regards!
Re: Hellen 128 question m113 5.0
ECU comes assembled and with software
ECU comes without calibrations specific to your m113 5.0 engine, you would need to hire a tuner/dyno shop to calibrate the ECU.
- md_sanci
- Github Username: shadowm60
- Slack: Alex M
- Contact:
Did you checked if you have 128 pin car connector?
You do have to make engine calibration after you installed hellen in the car, i can support with the make it run part, but final calibration would make sens to do it on a dyno.
Sent from my SM-A528B using Tapatalk
