Haltech CAN bus Communication don't work.
Posted: Wed Mar 23, 2022 2:53 am
by hugovw1976
Hi , I have a custom board base on Proteus running latest firmware ("rusEFI 2022.03.16.proteus_f4.1421086421"), I have a AIM MXL Pista dash and test Haltech dash and don't work, I also check with VAG and AIM and this work fine (can communication it's fine in board).
I check in Console and Haltech don't send any messages, I want the Haltech protocol because have more information, It's posible to check this error.
Thanks.
https://github.com/mck1117/proteus/issues/111
Re: Haltech CAN bus Communication don't work.
Posted: Wed Mar 23, 2022 2:18 pm
by hugovw1976
I check code apparently Haltech dash is not initiate:
void canDashboardBMW(CanCycle cycle);
void canDashboardFiat(CanCycle cycle);
void canMazdaRX8(CanCycle cycle);
void canDashboardW202(CanCycle cycle);
void canDashboardBMWE90(CanCycle cycle);
void canDashboardVagMqb(CanCycle cycle);
void canDashboardNissanVQ(CanCycle cycle);
void canDashboardGenesisCoupe(CanCycle cycle);
void canDashboardAim(CanCycle cycle);
void updateDash(CanCycle cycle) {
// Transmit dash data, if enabled
switch (engineConfiguration->canNbcType) {
case CAN_BUS_NBC_BMW:
canDashboardBMW(cycle);
break;
case CAN_BUS_NBC_FIAT:
canDashboardFiat(cycle);
break;
case CAN_BUS_NBC_VAG:
canDashboardVAG(cycle);
break;
case CAN_BUS_MAZDA_RX8:
canMazdaRX8(cycle);
break;
case CAN_BUS_W202_C180:
canDashboardW202(cycle);
break;
case CAN_BUS_BMW_E90:
canDashboardBMWE90(cycle);
break;
case CAN_BUS_MQB:
canDashboardVagMqb(cycle);
break;
case CAN_BUS_NISSAN_VQ:
canDashboardNissanVQ(cycle);
break;
case CAN_BUS_GENESIS_COUPE:
canDashboardGenesisCoupe(cycle);
break;
case CAN_AIM_DASH:
canDashboardAim(cycle);
default:
break;
Posted: Wed Mar 23, 2022 2:54 pm
Nice just made this better
https://github.com/rusefi/rusefi/commit/f490b499971f19e01e9f2dbe165309e1bc862d36 would be about 20 minutes to build snapshot
but that also shows that this code is totally untested and unproven
Posted: Wed Mar 23, 2022 5:29 pm
by hugovw1976
Thanks
Enviado desde mi SM-G988U1 mediante Tapatalk
Posted: Thu Mar 24, 2022 3:08 am
by hugovw1976
I compile firmware with the new lines on can_dash.cpp, and can confirm Haltech can communication works now, just need to check if all the channel are correct but I don't have time until the weekend.
Thanks.
Posted: Wed Mar 30, 2022 4:36 pm
by hugovw1976
Check all output channels and looks good, just the Intake temperature and fuel level is not declared in can_dash.cpp
/* 0x3E0 = 5Hz rate */
CanTxMessage msg(0x3E0, 8);
/* Coolant temperature in K y = x/10 */
tmp = ((Sensor::getOrZero(SensorType::Clt) + 273.15) * 10);
msg[0] = (tmp >> 8);
msg[1] = (tmp & 0x00ff);
/* Air Temperature */
msg[2] = 0x00;
msg[3] = 0x00;
/* Fuel Temperature */
msg[4] = 0x00;
msg[5] = 0x00;
/* Oil Temperature */
msg[6] = 0x00;
msg[7] = 0x00;
Air temperature is the intake air temperature. must be :
tmp = ((Sensor::getOrZero(SensorType::Iat) + 273.15) * 10);
msg[2] = (tmp >> 8);
msg[3] = (tmp & 0x00ff);
msg[4] = 0x00;
msg[5] = 0x00;
msg[6] = 0x00;
msg[7] = 0x00;
Fuel Level in code:
/* 0x3E2 = 5Hz rate */
CanTxMessage msg(0x3E2, 2);
/* Fuel Level in Liters */
msg[0] = 0x00;
msg[1] = 0x00;
must be:
tmp = (Sensor::getOrZero(SensorType::FuelLevel)* 10);
Intake Air Temperature tested and working, Fuel Level not nested.
Posted: Wed Mar 30, 2022 4:46 pm
Please-please-please invest an hour of your time to properly fork
https://github.com/rusefi/rusefi and push changed into your fork?
Reminder that worst case scenario you can edit files via the browser or upload files into your fork of
You fix is valuable but please make it move valuable by going the proper GH route to reduce my efforts to accept your fix.
Posted: Wed Mar 30, 2022 5:15 pm
by hugovw1976
AndreyB wrote:Please-please-please invest an hour of your time to properly fork
Sorry I'm very new on this, is any guide to made fork.
Posted: Wed Mar 30, 2022 5:38 pm
hugovw1976 wrote: ↑Wed Mar 30, 2022 5:15 pm
Please go over
https://docs.github.com/en/get-started/quickstart/fork-a-repo
We are talking about one click in the right-top corner of
https://github.com/rusefi/rusefi once you have a github account.
Posted: Wed Mar 30, 2022 5:39 pm
Also forum is not a chatting platform.
Slack is the chatting platform we should be using for chatting see
https://rusefi.com/forum/viewtopic.php?f=13&t=1198
