Proteus .04 RPM Spiking, Trigger Error?
Cadence
I hope I am not bombarding too much in here. I am finally able to put real miles on the car and am working through issues as they arise.
I am working through revving the engine out to limiter now and I am getting RPM spikes. These spikes are causing the limiter to kick in early. The spikes according to the logs seem to be double the immediately previous RPM. The engine is a BMW M42 4 cyl 1.8L with 60/2 trigger wheel with the stock VR sensors on the Crank and Cam. RusEFI is set to "VW 60/2". I know there was some contention with this trigger setting, but I didn't want to change anything without some confirmation or suggestion. I used this trigger setting for first start and it has been working so far. I have attached a log where the spikes can be seen several times. Looking at the vehicle speed therea re also spikes high and low around the same times as the RPM spikes are happening.
Examples in the linked Log in seconds 95.309, 107.559, 444.964 - 448.562, 766.339 - 768.584
Proteus 0.4
Firmware:v20211008@28919
Tune:https://rusefi.com/online/view.php?msq=689
Log: https://rusefi.com/online/view.php?log=386
Proteus 0.4
Re: Proteus .04 RPM Spiking, Trigger Error?
At the moment your tune says
* "I have 60/2 on the CAM" (that's not what you want)
* I am hesitant about CAM - I have input configured but more is inactive
Complexity of trigger configuration is a very known issue unfortunately. https://github.com/rusefi/rusefi/issues/3401 is the most recent one, some minor improvement was actually done under https://github.com/rusefi/rusefi/issues/3401 please update your bundle to see fresh project, it would hopefully make it easier to spot "60/2 on the CAM" drama
considering your inactive cam it's hard to say while we have so many issues but it could be similar to https://github.com/rusefi/rusefi/issues/3269 which was closed but who knows
Please keep those amazing reports coming!
Cadence
I apologize, I linked my most current uploaded tune without checking it. I made cam changes before taking this log.
Here is the correct Tune that was loaded when taking the log: https://rusefi.com/online/view.php?msq=692
Well, that explains how you have the hiccup - you've fixed half of configuration issues.
Please consider addressing the other half of configuration issues:
please consider upgrading to latest bundle which would make your configuration issue more explicit
I've reopened https://github.com/rusefi/rusefi/issues/3269
Right now I do not have an explanation. Let's start by updating project .ini and fixing your trigger setup. I bet issue would stay but maybe it would not?
vvt position ~= double his trigger offset, and he's somehow in "4 stroke cam" mode and that works? Double his trigger offset smells funny, like the same thing nik saw.
I think we are both trying to say "your RPM seems doubled please fix and take fresh logs"
Test #1: Set "operation mode" to "4 stroke without crank sensor", re-check trigger offset with timing light. Set cam inputs to NONE. Set spark mode to wasted spark if not already. Take a log. Does the blip still happen?
Test #2: Change nothing else, but add the cam input as it's configured now. Take another log. Does the blip still happen?
Cadence
I am updating bundle now. I should be able to complete these tests in about an hour and will respond with results.mck1117 wrote: ↑Tue Oct 26, 2021 6:22 pmTest #1: Set "operation mode" to "4 stroke without crank sensor", re-check trigger offset with timing light. Set cam inputs to NONE. Set spark mode to wasted spark if not already. Take a log. Does the blip still happen?
Cadence
I must have messed up the trigger offset set up when i set it originally(with a junky old timing light. When checking with a nice newer timing light today I had to change it from 114 to 124 and now it is all lining up.
When set to no cam and wasted spark there are no spikes and no hiccups.
When trigger is set to 4 stroke with cam, changing nothing else the spikes returned. It seems to be only when over 4000rpm. you can see in the log there are no spikes until 528.650 and that is the first time the engine is over 4000rpm.
Tune with corrected offset and trigger set back to no cam: https://rusefi.com/online/view.php?msq=694
New Log: https://rusefi.com/online/view.php?log=388
Having a look....
It does sound like it is indeed something weird with the cam sync, then.
Can you describe your hardware setup? The crank signal all looks fine to me. Where is your cam sensor? What kind of sensor? What is the target the sensor is sensing?
Can you share a snip of the rusEFI console's engine sniffer, just running at idle? I'm interested in what your cam signal looks like in relation to the crank.
Cadence
The cam sensor is VR and is on the exhaust cam. you can see the side of it in the second picture. The target is a single peg sticking out of the cam gear. both cams have the peg but only exhaust has a sensor. TS would not allow me to set the intake cam sensor to none so i have it set on the intake cam.mck1117 wrote: ↑Tue Oct 26, 2021 10:56 pmIt does sound like it is indeed something weird with the cam sync, then.
A few things to try:
I can take a console log here shortly. I am eating dinner right now.
It's no big deal if it's not *actually* on the intake cam, since you don't actually have VVT. Mine is configured to intake cam, but it's a single cam pushrod engine, so it's *also* the exhaust cam.Cadence wrote: ↑Tue Oct 26, 2021 11:24 pmThe cam sensor is VR and is on the exhaust cam. you can see the side of it in the second picture. The target is a single peg sticking out of the cam gear. both cams have the peg but only exhaust has a sensor. TS would not allow me to set the intake cam sensor to none so i have it set on the intake cam.
Cadence
maybe a bad sensor?
what engine sniffer looks unusual. why does it not show legend?
Cadence
This is from the bundle I downloaded today. The Legend shows only when I mouse over it. Could be potato computer.
Hmm, maybe. It's possible that the VR interface on Proteus is unhappy about your single tooth VR setup. Possible to replace with a hall sensor in the same hole? Alternatively you could just run wasted spark and not worry about the cam sensor at all. My approximately similar setup on my racecar (4cyl turbo, 60-2 crank, individual coils, etc) runs great with no cam sensor whatsoever.
he's also zoomed suuuper far in on the cam tooth
Kind of side note - note your warning count / last warning.
Ideally we want to address all of these one by one
Cadence
I have seen pictures of a cherry hall adapter. I may try my hand at making one. In the meantime I will set it back to wasted spark. My goal is to take advantage of all of the features I possibly can. And hopefully provide good information back.
I will take a look at the warn count and last warn when I get back to it tomorrow and address those as well.
Cadence
These are the warnings on these logs.
CUSTOM_VVT_SYNC_POSITION = 6675,
CUSTOM_RE_ADDING_INTO_EXECUTION_QUEUE = 9011,
* This indicates an issue with coil control - pin was not high when we were trying to set it low.
CUSTOM_OUT_OF_ORDER_COIL = 9012,
* Commanded fuel exceeds your fuel injector flow
It looks like all these are related to the cam sync issues. The fuel injector duty cycle is spiking over 100% when the rpm is spiking. I will take a log on wasted spark tonight and see if these return or if there are any new or other warns.
Cadence
As another side note. Is it possible to add a coin cell to Proteus 0.4 for real time stamps on the logs?
batter would be great question for proteus thread
back to trigger error codes are at https://github.com/rusefi/rusefi/blob/master/firmware/controllers/algo/obd_error_codes.h
- MHTSOS
- Slack: Dimitri C
The period of a single tooth cam would be over 85ms on low rpms so could this be a case of the dreaded watchdog?
