[help needed] Frankenso: does anyone have pictures for this board
- Github Username: kylan8129213
- Slack: huh
if anybody has pictures of a fully build board identical to mine for a NA 1994 1.8L miata please send them to me or help me build this board because my board is different from all the pictures out there
Re: Frankenso: does anyone have pictures for this board
There are some pictures at https://github.com/rusefi/rusefi_documentation/tree/master/Hardware/Frankenso
Most sections of the board are pretty much the same
Also useful is interactive BOM https://rusefi.com/docs/ibom/frankenso_latest.html
- Slack: huh
what does DNP mean for value
Do Not Populate
- Slack: huh
i also was not givven enough 1uf
if i just don't have something or dont have enough what do i do
How blocked are you by that? How many were included and how many do you need total?
- Slack: huh
can i use 4.7pf insted of 4.7uf i dont have 4.7uf
I would not recommend since those are probably x1000 wrong? How does 4.7pf convert into uf and vise versa?
Can you please post close-ups of MAX9926 soldering? The pictures you've posted so far are raising some questions.
- Slack: huh
how does this seem?
At the moment I am concerned at least about this area. Can you please post a better picture focusing on this component exactly?
- Slack: huh
max9962
I guess that looks better now. Are you using soldering paste and hot air or some other approach?
- Slack: huh
im just using a soldering iron and solder
- Slack: Orchardperformance
Have you looked at this thread?
https://rusefi.com/forum/viewtopic.php?f=4&t=1409
I also strongly recommend watching this video for some pointers on soldering the RE hardware.
Hi. Im seriously concerned with the quality of the soldering. I can see many solder bridges and misaligned chips. You really need to take your time and do it right. I dont mean this to be insulting and i hope it isnt taken this way. Is there a reason you went with this kit rather than getting the premade Hellen?
- Slack: huh
because im broke
- Slack: huh
does this look like it will blow up
in the picture does it look like it will blow up when i plug it in or does the front look good? for 1994 1.8l miata
Re: does this look like it will blow up
Yes
Also all the components here are NOT assembled if you are planning to snap green board in.
- Slack: huh
what do i need for green board and why does it look like it will blow up
what do those mean
what do those mean
Re: what dies OR and OPT mean
huh?
- Slack: huh
in the digram it says OR and OPT for some of the values
0R? zero ohms?bigredproject wrote: ↑Sun Oct 24, 2021 1:01 amin the digram it says OR and OPT for some of the values
- Slack: huh
for value what would 1500 .1% be in the resistors because there is no 1500 resistor
No way.
- Slack: huh
on my sheet it shows that there is no 1500 and I looked through all of the resistors and there is no 1500 so what do I do
I am sorry but you are not qualified to assembled this kit.
- Slack: huh
wait 1.5 is 1500?
p means Pico (10^-12)
n means nano (10^-9)
u means micro (10^-6)
K means thousand (10^3)
M means million (10^6)
https://en.wikipedia.org/wiki/Unit_prefix
- Slack: huh
how does this look
I know it is not the prettiest but does it look finished and ready to plug into USB?
