Convert MicroRusEFI from Hall to VR Version?
samsonwilliams
Post by samsonwilliams »
Hello, I bought a MicroRusEFI with the hall effect configuration, but I'd much prefer to continue with the ability to use a VR sensor for my current project. The wiki noted that you can modify the board "with few resistor changes" to go from one or the other (under the "Capabilities" section). I'm having a lot of difficult finding information on this, so if someone could point me in the right direction, or explain how I'd do that, I'd appreciate it!
Last edited by samsonwilliams on Mon Nov 25, 2024 2:24 am, edited 2 times in total.
Re: Convert MicroRusEFI from Hall to VR Version?
orviston
Post by orviston »
Have you had any luck yet, I am kind of stuck with the uaefi in the same way. I can't get the inputs to read VR signals yet - not sure if modifying the uaefi is required.. tough to navigate here. I followed you link but don't see how it answered you issue (was hoping it would help me) .. Dennis
orviston
Post by orviston »
got this issue solved.. replaced the cam pickup guts in the disti and was able to get a good square wave off the ford TFI, with that I am not firing the coils. on to the next items; TPS, MAP, etc..
