Hi everyone,
I'm facing a problem with the dwell time in my setup, and I’m hoping someone can help me troubleshoot. Here are the details of my configuration:
Engine: VW AP 1.8-liter, 4 cylinders
Distributor: Hall sensor with an internal 4-0 toothed wheel
Fuel Injection: Four injectors pulsing simultaneously
Dwell Time: Set to 3.6 ms across all RPM ranges
Firmware: Running the firmware for the Discovery F407 board
The issue occurs when the engine is at idle (around 1000 RPM) and I accelerate rapidly. In this situation, the dwell time decreases significantly, even reaching zero momentarily. However, if the engine is at 2000 RPM and I accelerate quickly, the problem does not occur, and the dwell remains stable.
This behavior is causing ignition instability during rapid throttle changes at low RPM.
Has anyone experienced a similar issue or knows what might cause the dwell time to drop like this? Are there specific settings or configurations I should double-check to ensure consistent dwell time in this scenario?
Any advice or suggestions would be greatly appreciated!
Thanks in advance for your help!
Dwell time not stable during quick acceleration
vtfvaldir
- Github Username: ValdirTerzettiFilho
Re: Dwell time not stable during quick acceleration
vtfvaldir
Sorry Andrey, I forgot to attach the log.
