VE & Ignition blend tables with RPM too low axis value
mk e
Post by mk e »
The VE and ignition blend table allows RPM as the blend parameter but have a max value limit of 1000 on the axis, so too low for most RPM based uses. There was talk of bigger VE table on discord and the thought was the blend table could be used to effectively add additional rpm points....but the axis limit is too low use rpm selection for anything but crank/idle. Looks like the Ignition blend is the same limit :(
Re: VE & Ignition blend tables with RPM too low axis value
Yep, that's an issue
a bit of progress but totally not complete fix https://github.com/rusefi/rusefi/commit/7537cc4deb5a61a22a44c018bcb813c3c78d8d38
mk e
Post by mk e »
Thank you Sir!
