Honda SC35 trigger sync issues
Posted: Mon May 29, 2023 4:15 pm
Hi
There is no stable synchronization during cranking - it can hit TDC correctly, it can miss by 90-180 degrees - full random.
If it hits TDC then the engine starts and runs great.
ECU alphax-4chan, Honda motorcycle four-stroke engine.
Crank - 36 tooth VR.
Cam - 1 tooth VR.
Additional capacitors are installed in both VR modules, adjusting the VR sensor threshold does not help.
https://rusefi.com/online/view.php?msq=1477
The 36 tooth trigger is not original, I also have the original 12 tooth trigger - same problems. I have logs for him too if needed.
Cam - 1 tooth VR.
