Fuel source for cranking - Fixed vs Fuel map
Posted: Fri Aug 13, 2021 11:28 am
by Biggie_254
Hi all,
Have an issue I am trying to troubleshoot and need help.. My injectors are all wired in correctly and on bench test I am able to get them firing.
When I try cranking the engine with "fuel source for cranking" set to Fuel Map, the injectors don't fire during cranking. (with the rail out)
When I try cranking with "fuel source for cranking" set to Fixed the injectors do fire but the car doesn't start.
All the maps for the M111 190e are set to fuel map so I am pretty sure this is the setting I need to go with. Any ideas why they're not firing under this setting.
https://rusefi.com/online/view.php?msq=618
Re: Fuel source for cranking - Fixed vs Fuel map
Posted: Fri Aug 13, 2021 5:04 pm
by mck1117
Can you take a log of cranking? If "fuel map" is injecting no fuel, it probably means something else is wrong.
Posted: Fri Aug 13, 2021 5:36 pm
by Biggie_254
hey. bear with me this was my first time attempting to log. connection kept cutting off so not sure it captured anything.
If not I can try again on Monday.
Cranking_1.zip
Posted: Fri Aug 13, 2021 6:24 pm
by mck1117
rusefi.com/online also accepts logs :)
Posted: Fri Aug 13, 2021 6:31 pm
by Biggie_254
Ah good call. I’ve uploaded it to the tune page.
