Gen 4 LS - no crank trigger
ykill
Post by ykill »
My crank trigger isn't received by my Proteus.
I'm not really sure what's happening.
Cam signal is received.
I moved my crank signal from digital 1 to digital 5 and updated my tune accordingly but still nothing.
I thought that I had and issue with wiring so I tried every positions possible.
Sensor is receiving 5v (in fact it's the same as the cam sensor)
Ground is good
I don't have an oscilloscope to confirm that I get signal from the sensor.
Sometime, when playing around, I can get signal for one or two revolutions.
Should I add a pull-up like I had on my megasquirt?
Any idea on what could cause this issue.
I'm pretty sure that it was working when I only had ETB, CAN and Cam/crank plugged in.
I changed firmware version between then and now, should I go back to the previous version?
I've been working on this issue for the last week and I'm out of idea
I'm sooooo close on starting the car 🤬
Re: Gen 4 LS - no crank trigger
Proteus has internal pullups on the digital inputs already.
Do you see anything on the trigger logger tab in tunerstudio?
ykill
Post by ykill »
Yeah, only the cam trigger
Many digital multimeters have Hz frequency mode, probe on PCB on back side of connector if you see frequency while someone else is cranking?
ykill
Post by ykill »
I will try that tonight!
Has this crankshaft/sensor combination run an engine before?
I ask because the 24x vs 58x trigger wheels need a different sensor (24x black sensor, 58x grey sensor). If they're mismatched then you'll get a crappy signal or no signal at all.
ykill
Post by ykill »
mck1117 wrote:
Thu Apr 27, 2023 9:31 pm
Yes, it was running in my MS3 before, signal was flawless
ykill
Post by ykill »
Thu Apr 27, 2023 9:24 pm
I tried to do so but it gave me khz instead of Hz (auto adjusting). It was acting weirdly so I'm not really sure this function worked correctly on my multimeter....
I'll try to find an oscilloscope
ykill
Post by ykill »
I attached a trigger log
It seems that I need to crank for really long until it gets recognized.
Signal wires aren't shield, could that be the cause?
ykill
Post by ykill »
Little update
Signal is way better.
It seems like removing the fan wires helped a lot.
I removed the CEL wire as well
but rpm is jumping a lot and I'm getting a lot of sync errors, if it was a VR, I would have thought that the starter is making noise since the wires are next to it.
I'm a little lost with that problem.
where do the sensor's ground and power wires go?
ykill
Post by ykill »
5v is coming from the white connector and I don't remember exactly but I'm pretty sure ground is going to sensor ground on white connector as well
I'd make sure that the ground wire is going to the ECU's sensor ground, and isn't connected to chassis/engine somehow. An easy test is to unplug the connectors from the ECU, then measure ohms between the sensor's ground pin and the block.
ykill
Post by ykill »
Now that I'm thinking about it, it's grounded on the chassis....
I'll ground it on the ECU
ykill wrote:
Fri Apr 28, 2023 10:11 pm
Ah hah, that'll do it! Our input voltage threshold is relatively low (2 volts or something? don't remember exactly), so even a "little bit" of ground offset can trip things up.
ykill
Post by ykill »
Haaaaa, I should've thought about that sooner...
Can I crimp it to another already existing sensor ground or should I bring new ones?
Shared sensors grounds are generally fine, not enough current there to cause an offset.
ykill
Post by ykill »
Ground didn't help but twisted a new wire outside the car and it worked so maybe the crimp didn't work, the noise of the ignition wires f'ed up the signal or the wire was broken.
I'll update later when I test
ykill
Post by ykill »
Well now I'm confused.
It stopped working with the wire outside the car...
ykill
Post by ykill »
I updated with today's snapshot of the firmware, it didn't work.
I forgot the key on for somewhere around half an hour.
I plugged and oscilloscope to see the signal and it was there and in tuner studio as well.
I'm not sure if it was the update that took time after rebooting or what but it's working now.
The cam sensor signal show 3 teeth instead of 1 but I can run batch for now at least
your cam sensor is likely "bosch quick start" pattern
ykill
Post by ykill »
I'm pretty sure I changed it to a single half moon but it's been a while so I'll try it
ykill
Post by ykill »
You were right, it was bosch quick start!
Thank you!:D
ykill
Post by ykill »
It seems like I'm always plagued withthis setup.
Crank signal looks fine for a while
Then it looks like it's having a hard time getting signal
Then it gets worse and worse
I'm starting to wonder if it's the sensor taking a crap on me...
ykill
Post by ykill »
Signal is perfect on the oscilloscope so I would be surprised that the sensor is dying...
ykill
Post by ykill »
Surprise surprise, the crank sensor was the culprit, it was causing most of my issues
Little question, though.
Shouldn't the trigger show square waves instead of lines?
keyword: "lazy hall" could be relevant (or not)
ykill
Post by ykill »
Another issue that I had as well.
Every tunes I looked at had between 84 and 86 degrees at the trigger angle.
Mine is at 40 and it looks like one or multiple cylinder is out of phase.
I tested every coils and they do follow firing order.
Could it be possible that the coils follow the same order as the injector? (Coil 1 if cylinder 1, coil 2 is on cylinder 8, 3 on 7, 4 on 2 etc... While injectors are mixed)
My tune is here:
https://rusefi.com/online/view.php?msq=1460
What is the question? Would bench test buttons help?
ykill
Post by ykill »
Is there a possibility that a bug causes the coils to follow the injectors hardware configuration instead of the coil hardware configuration while cranking/running?
Everything works well in bench mode
I will re-do the pinout of the injectors this weekend to make both follow the same order to test
