Hi. So I am trying to get my 1990 1.8 swapped miata to run on standalone. The car starts but it wont idle. I think it has something to do with not getting enough fuel.
Here is my tune: https://rusefi.com/online/view.php?msq=1182
It probably is something simple that I overlooked.
Any help will be greatly appreciated since I am at a loss for what to do
Thanks
[help needed] Start but doesn't idle
Re: Start but doesn't idle
Vane door has a mechanical switch to enable fuel pump on NA6 right? Do you have vane door with the switch or did you jump the fuel pump control wire?
BeerMoneyMotorsports
Update from Facebook. Car is running with some added fuel. It was going lean(18-20) and dying. Just tuning needed.
