Default 6 Cylinder firmware
dj_nexxus
Post by dj_nexxus »
Good day guys, love the project and anxious to get up and running and begin contributing back to the community, can anyone guide me on how to set the firmware up for six cylinders (injectors and ignition). I am hoping it can be done with the base firmware as I have it up and running in simulation mode and got it working with tuner studio and the console..Thanks in advance.
ZHoob2004
Re: Default 6 Cylinder firmware
Post by ZHoob2004 »
I haven't run a 6 cylinder, but I'm under the impression it's no different from any other engine configuration. Simply select the number of cylinders and the correct firing order in the base engine configuration page.
There are default configurations hard-coded into the firmware if you want to take a look at https://github.com/rusefi/rusefi/tree/master/firmware/config/engines
https://github.com/rusefi/rusefi/blob/master/firmware/config/engines/bmw_e34.cpp would be on the 6 cylinder engines. You can invoke the following command in rusEfi console to apply these defaults:
set engine_type 25
