[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [rusEfi] Subaru Impreza GF EJ151/EJ201 Superchargered #29 - Page 5 - rusefi.com
А какой сейчас вариант? Сейчас у нас есть только датчик колена, у которого симметричная форма? С симметричной формой сигнала колена нам двигатель не завести. Или есть желание стачивать зуб? Если форма колена станет несимметричная, то можно будет заводить попарным впрыском.
Собирать не обязательно, достаточно взять готовую скомпилированную.
Зажигание уже можно, потом нужно будет найти положение вмт. Моя синхрогизация будет в точке странной, пока ты не подвинешь в правильное место. Зелёная линия это вмт, нужно зелёную линию подвинуть правильно.
меня, правда смущают сообщения типа вот такого:
EngineState: gap=10.05/0.79/0.13 @ 12 while expected 7.00/9.00 and 0.00/100000.00 error=0
Это нормально?
как настроишь - так и будет. разве нет?
в тюнер-студии есть настройки, каким должен быть порядок впрыска при заводке и на заведённом моторе.
не знаю, как сейчас, но можно было подать синал на основные датчики - и оно будет формировать импульсы по впрыску и зажиганию.
симуляторе?
стартерные обороты сколько стоят? и на каких оборотах виден попарный впрыск? и вообще настройки тюнерстудии в отношении впрыска какие? там можно вообще везде выставить индивидуальный. или вовсе одновременный.
мы смотрим на каналы впрыска, или зажигания?
Тюнер студию лучше купить ...
Бесплатные крякнутые криво это всё пальцем в небо либо глючить будет либо ограничения в пораметрах ...
Настройки в тюнер студии ТЮНИНГ это уже другая тема ... для начало нужно завести мотор и чтоб он работал на холостых стабильно Сам ...
А потом тебе куча литературы читать отом что такое топливная смесь и прочии настройки мотора ...
Крякнутой версией не пользовался, пользуюсь той, что можно скачать с сайта.
Про купить я согласен, но когда действительно буду настраивать. Пока согласен, что нужно сначала завести.
Литературу про настройку и что такое смесь читаю регуряно последние пару лет
Как я помню в консоли пока тока отслеживаем графики коленвал распред впрыски короче тока эта часть график с полосочьками ...
Всё остальное все настройки уже в ТЮНЕР студии ...
Если на сегодня у тебя все полосечьки в консоли графике совпадают правильно то нужно переходить в тюнерстудию ...
Советую наити в инете или на форумах субаристов стандартную карту зажигания и стандартную карту топлива или хоть какие-нибудь карты от твоего мотора чтобы было от чего начинать и отталкиваться ...
я хз что за симулятор, тюнерстудия бесплатаная позволяет менять конфиг мотор. карты тыкать не пробовал - возможно и их тоже. по-мому платная нужна для автоматической отстройки?
http://rusefi.com/wiki/index.php?title=Manual:Try_It
его можно и под posix скомпилироваь, но бесплатная TunerStdudia не работает по TCP/IP так что гемморойно настраивать переброс tcp в виртуальный com. Это вообще без платы.
вспомнил, что-то такое с rus084 запускал. но, видимо, тогда особо нужды вникать, что это такое, и зачем оно нужно, не было.
вероятно, позволяет оттачивать карты без мотора?
