Noritake VFD displays- free samples
- abecedarian
If anyone is interested in displays: http://www.noritake-elec.com/evalkit-sample.php
They occasionally offer up different displays. This one is 24 x 6 character module.
US and Canada only.
US and Canada only.
Re: Noritake VFD displays- free samples
Only thing is we do not have that many UARTs available and I hate the 8 wire parallel port - so ideally I want to use these with SPISubmission Confirmed
Your inquiry was successfully sent.
Thank you for your interest in Noritake itron VFD Module.
I've seen http://www.411techsystems.com/HD44780-Serial-Adapter-Backpack-I2CSPI_p_117.html - but for some reason that's quite a lot of components on this board, why so? I was hoping to use just 74HC595 or MCP23S17 without much anything else.
- abecedarian
Use digital I/O pins to switch transistors and route the UART signals?russian wrote:Only thing is we do not have that many UARTs available and I hate the 8 wire parallel port - so ideally I want to use these with SPISubmission Confirmed
Software UART? I guess that's worth a try, tooabecedarian wrote:Use digital I/O pins to switch transistors and route the UART signals?
PS: would you be interested to implement that for stm32f4?
- abecedarian
Think of it more like 'multiplexed' UART.russian wrote:Software UART? I guess that's worth a try, tooabecedarian wrote:Use digital I/O pins to switch transistors and route the UART signals?
Route UART TX/RX to several pairs of transistors and selectively enable pairs of transistors to send the signals to whatever device.
Much like how SPI devices support 'chip enable' or 'chip select' lines.
Either way that's some twisted stuff.abecedarian wrote:Think of it more like 'multiplexed' UART.
I've made an impulsive purchase of http://www.ebay.com/itm/200984980018 - mostly for the SPI module. I am pretty sure the module should be available separately but I could not find it right away.
- hasse.69
- donator
I have this one ,serial board interface will i be able to use it?
http://www.ebay.com/itm/Board-Module-Port-IIC-I2C-TWI-SP-I-Serial-Interface-For-Arduino-1602-LCD-S9-/390701057958?pt=LH_DefaultDomain_0&hash=item5af79907a6
[img] [/img]
And combined with this 16X2 display:
http://www.ebay.com/itm/LCD-Display-Character-Module-LCM-16x2-HD4478Controller-Blue-Blacklight-1602-TE-/121201942149?pt=LH_DefaultDomain_2&hash=item1c3832de85
[img] [/img]
Bought for a Flightcontroller but never used.
Br , Hasse.
[img] [/img]
[img] [/img]
Br , Hasse.
- abecedarian
If all you wanted was the SPI/IIC/I2C module, http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=display+SPI+module&_sop=15russian wrote:Either way that's some twisted stuff.abecedarian wrote:Think of it more like 'multiplexed' UART.
- abecedarian
I don't know.hasse.69 wrote:I have this one ,serial board interface will i be able to use it?
Br , Hasse.
I'm working through figuring out how to use one of these
I just received.
... for free.
Yep, that's exactly the thing I was looking for! Yes, I think we should use character displays via SPI as one of the options of data output. Now question is who would implement thishasse.69 wrote:I have this one ,serial board interface will i be able to use it?
$118 does not work for me. Tell me about the free optionabecedarian wrote:I'm working through figuring out how to use one of these
I just received.
... for free.
But seriously - since not everyone would be able to get it for free, we should probably look somewhere else. Like bluetooth + cheap Android tablets + Android Dash software
- abecedarian
They're not free any more.russian wrote:$118 does not work for me. Tell me about the free optionabecedarian wrote:I'm working through figuring out how to use one of these
I just received.
... for free.
But if you think $118 is too much, check Mouser: $365.
Part of the reason I posted the link to Noritake was, besides the free thing, is that after the first 'free sample' I applied for I received an email about another sample offer... and another... and another. The third one is how I received the 'big' display (it's over 12" wide).
And I thought people working on car-oriented things might like a display.
- hasse.69
- donator
Maybe this one with the right Androidphone.
http://www.ebay.com/itm/Arduino-Wireless-Serial-4-Pin-Bluetooth-RF-Transceiver-Module-RS232-Backplane-/251283070563?pt=LH_DefaultDomain_0&hash=item3a81a35e63
[img] [/img]
I´m useless on software ie i don´t know nothing about programing.
But i´m good at searching and i have ideas , not always good ideas
Br , Hasse.
[img] [/img]
Br , Hasse.
We have a position of PR director open. In this role you would be responsible for searching for volunteers who would dare to solder & run rusEfihasse.69 wrote: But i´m good at searching and i have ideas , not always good ideas.
The plan is to use a bluetooth module. Hc-06 seems to be easiest to configure. At some point we would need to find it's physical layout so that we can solder them right to our pcb
- abecedarian
I might volunteer for the PR position, if someone ports the code to run on this.russian wrote:We have a position of PR director open. In this role you would be responsible for searching for volunteers who would dare to solder & run rusEfihasse.69 wrote: But i´m good at searching and i have ideas , not always good ideas.
Not quite as 'cool' as the STM discovery board, but cool nonetheless as its a dual-core, real-time oriented, ARM-M4 running both cores "lock step", as in both run the same code for error / fault checks and has ECC memory and other fault-tolerant considerations.
My MAP adapt board is also compatible with it.
Hercules RM42x LaunchPad is ARM-R4 - not ARM-M4
Theoretically it might be more suitable for more hardcore real-time stuff, but with only 32Kb of RAM we would lose all the simplicity of the programming style we are currently enjoying with our 192Kb of RAM. Oh, we would also lose ChibiOS
Let's face - internal combustion engines are slow appliances, it's not rocket science we are taking care of here.
- abecedarian
You need 192KB ram?
Not sure what to say.
I need most readable code I can afford with as many usability goodies as I can afford.abecedarian wrote:You need 192KB ram?
Here is the current RAM usage report.
As you see, just the engine configurations alone is 5K. Histograms is a utility for performance monitoring, a lot of RAM is used for logging buffers. I have 192Kb at my disposal and I am putting them to use. Simple code => faster rate of change => more features.
Can you have an ECU with 32Kb? Absolutely. Would you get way more comfort with 192Kb? For sure.
- abecedarian
No arguments from me.
Happy coding!
Happy coding!
I have received my sample last week, thank you @!
- abecedarian
Hope you have fun with it.
It would be a nice in-dash for something... throw in some cap-sense buttons with LED backlights and be set.
