rusefi.com The most advanced open source ECU 2024-10-01T18:30:24 https://www.rusefi.com/forum/app.php/feed/topic/2811 2024-10-01T18:30:24 2024-10-01T18:30:24 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=50014#p50014 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by mpgmike — Tue Oct 01, 2024 6:30 pm
2024-10-01T16:28:38 2024-10-01T16:28:38 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=50013#p50013 <![CDATA[Re: Setting Crank Trigger (CKP)]]> https://github.com/rusefi/rusefi/wiki/uaEFI now has links to https://rusefi.com/docs/ibom/uaefi-d-ibom.html and https://rusefi.com/docs/ibom/uaefi-a-ibom.html
Statistics: Posted by AndreyB — Tue Oct 01, 2024 4:28 pm
2024-10-01T15:34:48 2024-10-01T15:34:48 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=50012#p50012 <![CDATA[Re: Setting Crank Trigger (CKP)]]> BadParts5.png
Statistics: Posted by mpgmike — Tue Oct 01, 2024 3:34 pm
2024-09-18T15:32:17 2024-09-18T15:32:17 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49962#p49962 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by mpgmike — Wed Sep 18, 2024 3:32 pm
2024-09-18T03:29:10 2024-09-18T03:29:10 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49961#p49961 <![CDATA[Re: Setting Crank Trigger (CKP)]]> BadPart3.png
Haven't had a chance to test it, as today I swapped the older intake manifold for the newer style (more than meets the eye).
Statistics: Posted by mpgmike — Wed Sep 18, 2024 3:29 am
2024-09-15T17:23:53 2024-09-15T17:23:53 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49952#p49952 <![CDATA[Re: Setting Crank Trigger (CKP)]]>
I haven't measured the current draw on the LS coil's Signal input, so I don't know if 50 mA is dangerously close, or if it was just a fluke failure.
Statistics: Posted by mpgmike — Sun Sep 15, 2024 5:23 pm
2024-09-15T15:42:32 2024-09-15T15:42:32 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49950#p49950 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by AndreyB — Sun Sep 15, 2024 3:42 pm
2024-09-14T23:15:06 2024-09-14T23:15:06 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49945#p49945 <![CDATA[Re: Setting Crank Trigger (CKP)]]>
https://toshiba.semicon-storage.com/info/TBD62783AFG_datasheet_en_20160511.pdf?did=30523&prodName=TBD62783AFG
I see you using ST, Microchip, TI, and other components. If you don't want to use the Toshiba version, many other companies make theirs, so you have options.
Statistics: Posted by mpgmike — Sat Sep 14, 2024 11:15 pm
2024-09-14T15:35:45 2024-09-14T15:35:45 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49943#p49943 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by mpgmike — Sat Sep 14, 2024 3:35 pm
2024-09-14T15:28:44 2024-09-14T15:28:44 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49942#p49942 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by mpgmike — Sat Sep 14, 2024 3:28 pm
2024-09-14T15:28:04 2024-09-14T15:28:04 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49941#p49941 <![CDATA[Re: Setting Crank Trigger (CKP)]]> https://github.com/andreika-git/hellen-one/issues/378
Statistics: Posted by AndreyB — Sat Sep 14, 2024 3:28 pm
2024-09-14T15:22:06 2024-09-14T15:22:06 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49940#p49940 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by AndreyB — Sat Sep 14, 2024 3:22 pm
2024-09-14T15:19:14 2024-09-14T15:19:14 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49939#p49939 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by mpgmike — Sat Sep 14, 2024 3:19 pm
2024-09-14T14:26:30 2024-09-14T14:26:30 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49938#p49938 <![CDATA[Re: Setting Crank Trigger (CKP)]]> Statistics: Posted by mpgmike — Sat Sep 14, 2024 2:26 pm
2024-09-13T17:54:35 2024-09-13T17:54:35 https://www.rusefi.com/forum/viewtopic.php?t=2811&p=49937#p49937 <![CDATA[Re: Setting Crank Trigger (CKP)]]> cTestOut1.png
Statistics: Posted by mpgmike — Fri Sep 13, 2024 5:54 pm
