rusefi.com The most advanced open source ECU 2022-11-30T03:56:22 https://www.rusefi.com/forum/app.php/feed/topic/2464 2022-11-30T03:56:22 2022-11-30T03:56:22 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46804#p46804 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by BeerMoneyMotorsports — Wed Nov 30, 2022 3:56 am
2022-11-18T06:12:55 2022-11-18T06:12:55 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46710#p46710 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 6:12 am
2022-11-18T06:00:12 2022-11-18T06:00:12 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46709#p46709 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 6:00 am
2022-11-18T05:59:46 2022-11-18T05:59:46 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46708#p46708 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 5:59 am
2022-11-18T05:57:48 2022-11-18T05:57:48 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46707#p46707 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 5:57 am
2022-11-18T05:56:28 2022-11-18T05:56:28 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46706#p46706 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 5:56 am
2022-11-18T05:54:38 2022-11-18T05:54:38 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46705#p46705 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 5:54 am
2022-11-18T05:54:19 2022-11-18T05:54:19 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46704#p46704 <![CDATA[Re: 10th Anniversary #0739]]> Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 5:54 am
2022-11-18T05:51:12 2022-11-18T05:51:12 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46703#p46703 <![CDATA[Re: 10th Anniversary #0739]]>
I had a cool license plate back in Chicago but... A lot has changed since :)
Statistics: Posted by AndreyB — Fri Nov 18, 2022 5:51 am
2022-11-18T06:21:24 2022-11-18T05:48:58 https://www.rusefi.com/forum/viewtopic.php?t=2464&p=46702#p46702 <![CDATA[10th Anniversary #0739]]>
Mods:
Power:
Beer Money Motorsports ECU powered by RusEFI
Custom CAI with airbox and foglight air duct
Mazdaspeed Intake Camshaft
Racingbeat 4-1 Header
Cobalt Midpipe
Racingbeat Dual Tip Muffler
Moroso Oil Catch Can
DIY Audi R8 COP with Flowforce Bracket
Flowforce 380 Fuel Injectors
ATI Superdamper with 32/2 Timing Wheel
Flyin Miata Coolant Reroute
TDR 11.8 lb Flywheel
SPEC Stage 1 Clutch
Cosmetic/Exterior:
JDM Mazdaspeed Wing
Gen 1 SPEC Miata 949Racing 6UL Wheels
LRB Aluminum Undertray
Hard Dog M2 Sport Roll Bar
DanDak Sequential Third Brake Light
Morimoto Headlight Projector Retrofit with 5500k HIDs
Morimoto XB Fog Light
Interior:
Revlimiter 10AE Gauges
A Pillar Gauges: KaN Gauge and AEM Wideband
MiataRoadster Tall Angled Shifter
NB2 Black Leather Seats
Revlimiter Retro Window Switches
DIY Toggle Switch Panel (Replaces airbag switch)
Blue Seatbelts
Suspension:
FM Front Sway Bar
Hard S Rear Sway Bar
Speedsage Delrin Sway Bar Bushings with Zerks
Flyin Miata Frame Rails
OEM Bilstein Shocks
Superpro Poly Differential Inserts
DIY Modifications:
Relay to start in Neutral but not in Gear
Relay to power Wideband only when engine is running
Ignition light with fade
Switch to turn on license plate lights as trunk lights
Modified trunk lock to allow trunk lever lockout
Modified OEM Oil Pressure Gauge to work with true oil pressure sensor
Wired Window Switches directly to battery
Leather shifter and ebrake boots
Additional Sensors:
Aux 1 Oil Temp Sensor
Aux 2 Temp; varies, usually related to air temp testing
Oil Pressure Sensor
Future Projects:
JDM Squaretop Manifold
VVT Head with .020" shave
Micro RusEFI board as additional input controller
DIY Bilstein Coil Overs
Superpro Poly Bushings
Statistics: Posted by 10AE0739 — Fri Nov 18, 2022 5:48 am
