Have an issue I am trying to troubleshoot and need help.. My injectors are all wired in correctly and on bench test I am able to get them firing.
When I try cranking the engine with "fuel source for cranking" set to Fuel Map, the injectors don't fire during cranking. (with the rail out)
When I try cranking with "fuel source for cranking" set to Fixed the injectors do fire but the car doesn't start.
All the maps for the M111 190e are set to fuel map so I am pretty sure this is the setting I need to go with. Any ideas why they're not firing under this setting.
https://rusefi.com/online/view.php?msq=618Statistics: Posted by Biggie_254 — Fri Aug 13, 2021 11:28 am
