rusefi.com The most advanced open source ECU 2020-04-05T01:40:43 https://www.rusefi.com/forum/app.php/feed/topic/1679 2020-04-05T01:40:43 2020-04-05T01:40:43 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=36058#p36058 <![CDATA[Re: Fast start features]]>
Perhaps I will enhance the starting ability by adding supercapacitor.
Or a proper battery ;)
Seriously, its easy to get caught up in trying to make something perfect and end up with something unusable or fragile instead.....I've fallen for that many times over the year :oops:
Statistics: Posted by mk e — Sun Apr 05, 2020 1:40 am
2020-04-01T21:00:43 2020-04-01T21:00:43 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=36014#p36014 <![CDATA[Re: Fast start features]]> But for my very standard engine with a bike battery, I would like to have some margin not to stay caught in a desert place. Perhaps I will enhance the starting ability by adding supercapacitor.
Statistics: Posted by JPh — Wed Apr 01, 2020 9:00 pm
2020-03-31T14:48:18 2020-03-31T14:48:18 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35968#p35968 <![CDATA[Re: Fast start features]]>
When my engine finally goes back together I will be adding an oil pressure transducer to feed pressure info to the ECU and will use that to enable fuel during cranking and probably to force a limp condition at below normal oil pressure and shutdown at some low oil pressure value. Still just a plan at the moment but as I continue to repair damage from low running with low oil pressure because I didn't believe the gauge it a pretty firm plan along with a more full appreciation of the standard approach of redundant sensors on critical items.
just a though
Statistics: Posted by mk e — Tue Mar 31, 2020 2:48 pm
2020-03-31T12:52:54 2020-03-31T12:52:54 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35966#p35966 <![CDATA[Re: Fast start features]]>
Just something to note here, I have found the lower my battery charge the longer the engine takes to fire, with a charged battery I can get OEM quality starting.
I am investigating this a little as I am wondering if this is an effect of not having a voltage correction for dwell and a large voltage drop during cranking.
Whats your cranking settings now?
I am thinking of enrichments etc you had best luck with.
Statistics: Posted by 960 — Tue Mar 31, 2020 12:52 pm
2020-03-31T09:15:56 2020-03-31T09:15:56 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35963#p35963 <![CDATA[Re: Fast start features]]>
Statistics: Posted by Simon@FutureProof — Tue Mar 31, 2020 9:15 am
2020-03-22T06:54:19 2020-03-22T06:54:19 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35836#p35836 <![CDATA[Re: Fast start features]]> As stated above its the main condition of fast start.
Statistics: Posted by JPh — Sun Mar 22, 2020 6:54 am
2020-03-22T06:49:17 2020-03-22T06:49:17 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35835#p35835 <![CDATA[Re: Fast start features]]> I will be happy with such a starting.
Statistics: Posted by JPh — Sun Mar 22, 2020 6:49 am
2020-03-21T22:24:15 2020-03-21T22:24:15 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35824#p35824 <![CDATA[Re: Fast start features]]>
But we have to wait for cam sync to begin fuel and spark or does it switch to crank sync?
In fast spin-up mode, we wait for crank sync. Ignition/injection will start right after the first sync point of the primary trigger.
Please be aware that this mode works only for certain trigger types (e.g. 60-2).
I think it works on most trigger types with enough teeth - I know it works on my 24 tooth LS trigger pattern.
Statistics: Posted by mck1117 — Sat Mar 21, 2020 10:24 pm
2020-03-21T20:09:25 2020-03-21T20:09:25 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35823#p35823 <![CDATA[Re: Fast start features]]> iframe
Statistics: Posted by Abricos — Sat Mar 21, 2020 8:09 pm
2020-03-21T17:38:33 2020-03-21T17:38:33 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35821#p35821 <![CDATA[Re: Fast start features]]>
Statistics: Posted by andreika — Sat Mar 21, 2020 5:38 pm
2020-03-21T12:09:50 2020-03-21T12:09:50 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35813#p35813 <![CDATA[Re: Fast start features]]> With old-style distributor-based ignition you get the right spark immediately after you start cranking, while here we wait for the missed tooth + then another entire crank rotation (at least this was true some time ago).
Statistics: Posted by puff — Sat Mar 21, 2020 12:09 pm
2020-03-20T20:12:28 2020-03-20T20:12:28 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35808#p35808 <![CDATA[Re: Fast start features]]> On every rusefi start I have seen on videos, it seems allways to be some sort of a delay before something happens.
I hope I will soon have my engine starting to make measurements to compare between oem and rusefi.
Statistics: Posted by JPh — Fri Mar 20, 2020 8:12 pm
2020-03-20T19:48:01 2020-03-20T19:48:01 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35807#p35807 <![CDATA[Re: Fast start features]]>
Here's what a startup sounds like on my car (5.3L v8, no cam sensor connected, batch fuel, wasted spark):
iframe
(don't mind the tach reading zero :P )
The startup fueling isn't ideal, so it could probably start a bit faster with some tweaking. I know @OrchardPerformance has been doing some work to make his car start up really nice, so he might be able to share his progress here.
Statistics: Posted by mck1117 — Fri Mar 20, 2020 7:48 pm
2020-03-20T13:06:37 2020-03-20T13:06:37 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35804#p35804 <![CDATA[Re: Fast start features]]> But we have to wait for cam sync to begin fuel and spark or does it switch to crank sync?
Statistics: Posted by JPh — Fri Mar 20, 2020 1:06 pm
2020-03-20T10:27:00 2020-03-20T10:27:00 https://www.rusefi.com/forum/viewtopic.php?t=1679&p=35802#p35802 <![CDATA[Re: Fast start features]]>
I have read some lines about rusefi having fast start features
Can we switch to wasted spark and batch fuel during cranking?
Yes, that's true. If you enable this option, it will use batch fuel/wasted spark right after the first sync (until fully synced):
Statistics: Posted by andreika — Fri Mar 20, 2020 10:27 am
