Statistics: Posted by AndreyB — Tue May 08, 2018 6:02 pm
I already wrote this reply before I realized what you were doing here. I think it could work like that, but when we have direct access to the code and hardware I don't see much of a reason to not simply implement the feature properly rather than trying to work around it.There's already support for per-cylinder ignition timing offsets, right?
Might this combo work?
- Set to 4 cylinder, 2 stroke (90 degrees between cylinders)
- Ignition outputs 1/2 go to the 1st rotor, and 3/4 go to second
- Set extra ignition advance to 0/80/0/80 for channel 1/2/3/4 respectively.
I think this will make outputs 1/3 fire 180 degrees apart, and 2/4 fire 10 degrees after their respective first channels.
Statistics: Posted by ZHoob2004 — Tue May 08, 2018 4:07 pm
Statistics: Posted by mck1117 — Tue May 08, 2018 5:54 am
Statistics: Posted by AndreyB — Thu Apr 26, 2018 6:14 am
Statistics: Posted by Old Grey — Fri Apr 29, 2016 10:15 pm
Statistics: Posted by AndreyB — Fri Apr 29, 2016 10:10 pm
Statistics: Posted by Old Grey — Fri Apr 29, 2016 10:06 pm
Statistics: Posted by AndreyB — Fri Apr 29, 2016 9:49 pm
Statistics: Posted by Old Grey — Fri Apr 29, 2016 9:44 pm
